Go to Post To anyone who is discouraged about their team, don't let yourself get down. I've seen my team go from having a robot that barely moved (and I'm not kidding, we had keys falling out of gearboxes) to this year with a robot that is ACTUALLY GOING TO WORK. Don't lose hope, stick with FIRST! - ZipTie3182 [more]
Unread 05-03-2009, 20:09
ZSLAYTER ZSLAYTER is offline
FTC #2882
ZSLAYTER is an unknown quantity at this point
Question [FTC]: Using two Hitechnic Motor Controllers in LabView
Hey, does anybody know how to program in two Hitechnic Motor controllers in Labview, because we have three motors, and in labview, it only gives the choice between Motor A, or Motor B! How do I get a third motor programmed??
Unread 05-03-2009, 21:43
jlester jlester is offline
FRC #1533
jlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to beholdjlester is a splendid one to behold
Re: [FTC]: Using two Hitechnic Motor Controllers in LabView
It depends on how you wired the second controller. For each NXT Port, the program assigns the first (directly connected) controller number 1, the next one is 2, and so on. So, here are the possible answers:
(1) If you attached it directly to a different Port on the NXT, then you need to use that Port number on your FTC Move Motors vi, and it will be controller 1 and Motor A.
(2) If you daisy chained the second controller to the output of the first motor controller, then you need to name it as Controller 2 on your FTC Move Motors vi, with the same Port number as the other motors.
(3) If you daisy chained the second controller to the output of the Servo Controller, which was daisy chained to the output of the first motor controller, then it is controller 3 on your FTC Move Motors vi.
Our team used option 3, so on our program the drive motors are Motors A and B on port 1, controller 1. The arm motor is connected to the second controller, so on our program it is Motor A and port 1, controller 3.
Hope this helps.
Unread 08-03-2009, 10:36
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
That's a point worth highlighting...
To control a third "independent" motor, you need a second motor controller.
Phil.
Phil Malone
http://www.GEARSinc.org
[FTC]: OUT OF MOTOR CONTROLLERS?!?!?!? ttldomination FIRST Tech Challenge 6 09-02-2009 18:48
[FTC]: Labview can't use two controllers dman14 FIRST Tech Challenge 8 04-02-2009 21:09
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
