Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
Unread 24-03-2009, 23:09
MasterRobot's Avatar
MasterRobot MasterRobot is offline
<= Psychedelic Cloud....
FRC #2438 ('Iobotics)
Team Role: Animator
MasterRobot will become famous soon enoughMasterRobot will become famous soon enough
Team 2438 RT-AWD Drive Train
Team 2438 presents their RT-AWD Drive-Train.
Reverse Tricycle - All Wheel Drive
It is very different from the drive trains that have been seen this year. The RT-AWD Drive Train is 3-Wheeled with the back wheel being a rotating double-wheeled pod. (Back-Wheel Pod)
The 3-wheel design allows for more control in turning. Though it is a 3-wheel design, the RT-AWD drive train so far seems to be stable. The only draw back so far is that the driver train is quite heavy because of the pod, and the fact that it is built from Bosch. If this drive train works out, we hope to improve on it to make it a very powerful competitive drive train.
http://www.youtube.com/watch?v=wyP-IlkeKZA
Unread 25-03-2009, 10:22
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Team 2438 RT-AWD Drive Train
Rear wheel pod looks very interesting. What are you using for the lower bearings/turntable? And how is turning driven, a large gear or sprocket?
You can lighten it by using a single reduction in the gearbox, or an AM stacker box(1 lb vs. 2.5 lb), then further reduction in the sprockets & chain. Are you using #25 chain?
Unread 25-03-2009, 10:58
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
That is truly impressive. How did it do in competition?
Unread 25-03-2009, 16:25
Team Role: Animator
this is the bottom side of the pod.
its a big gear attached to a 12" diameter turntable, run by a smaller gear.
we recently also installed a petentiometer and have a closed loop system for the turning of the pod. Yes it is #25 chain and we are looking forward to see how it does in the upcoming Hawaii regional
Unread 25-03-2009, 16:50
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
If you guys want some more inspiration for it, look at pictures of Bomb Squad, 16's drive. They do 3 wheel crab, which is the premise of your drive, except your front two wheels don't turn. It could be of some use.
You could really look at any crab drive you find to get some inspiration for your rear pod. The concepts look very similar.
Bomb Squad video: http://www.youtube.com/watch?v=gxsh4...e=channel_page
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 29-03-2009, 01:13
Team Role: Animator
In the end, we were very pleased with the drive. It allowed us to move and maneuver very quickly, with maximum efficiency in turning. This allowed us to become a high defense team that was able to pin and block many of the powerful high scoring robots at the competition.
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
pic: Team 1296 drive train Redo91 Robot Showcase 8 15-02-2007 00:01
pic: Team 11's Drive train CD47-Bot Robot Showcase 4 07-03-2004 21:40
pic: Team 60 Drive Train Parts CD47-Bot Robot Showcase 17 07-02-2004 01:58
