Go to Post The ever popular Safety Tip Of The Day: Do Not Lick Wheel While In Motion The other popular one was: Remember Stupid Hurts - Joe J. [more]
Unread 04-04-2009, 12:03
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Small question
I wish to know what type of cable does this use
Is it an IO or a PWM?
Unread 04-04-2009, 12:17
Re: Small question
I'm not sure I understand the question. I believe most people use "PWM cables" for it, but only the ground and signal wires. The +5 wire needs to be cut back and covered so it doesn't accidentally short to anything. The other end of the cable connects to a digital input on the control system.
Unread 04-04-2009, 13:47
AKA: Yamil Asusta
Re: Small question
Well I haven't seen the piece myself...I just want to make a limit switch for a motor. When it hit that thing it will stop.
So I thought that piece would be great.
By the connections I was reffering in LV. What type of VI is that? IO o PWM? Because I believe it is a digital input...
Unread 04-04-2009, 14:09
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Small question
Sounds like you want a different part. That switch is for measuring pneumatic pressure; I would suggest Kamen Tote>>Gates Pack>>Microswitch.
In response the other half of your question, I/O stands for Input/Output, in this case you want digital in, so that's the one you want. PWM is Pulse Width Modulation, which is for controlling motors.
--Ryan
FRC 766, 2015-, Mentor
Unread 04-04-2009, 14:39
Re: Small question
Yes, that's a digital input.
In LV it's under WPI Robotics Library -> I/O -> DigitalInput
Unread 04-04-2009, 15:20
AKA: Yamil Asusta
Re: Small question
Thanks guys
Well I'll ask the guys to search for it since will be making modifications to our bot in Atlanta and that is a crucial part right now!
Unread 13-04-2009, 22:39
JasonF JasonF is offline
FRC #2848 (The All Sparks)
JasonF is an unknown quantity at this point
Re: Small question
Yeah you are just looking for a micro Switch. I took an interesting Assembly from an old garage door that had two micro switches at adjustable heights which were toggled when the door was all the way up/down.
So if you want to do a two way toggle, its a nifty design if you don't want to start from scratch.
But yeah, a microswitch which you can rip a PWM apart for wires with pinning already in.
That pressure switch uses a Digital Input on the Breakout board as previously described.
Good Luck in ATL, hopefully We will all see what the microswitch is for!
Small question elbuo Programming 2 14-01-2009 14:41
Small, very easy Labview question (Hopefully) 1733_programmer LabView and Data Acquisition 2 08-12-2006 15:48
Small question... emis815 General Forum 2 06-01-2006 19:02
Small Regionals Nathan Pell Regional Competitions 14 10-11-2004 22:24
Small problem Cadetdan Electrical 1 10-02-2004 15:17
