Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 23-05-2009, 08:58
Dark element's Avatar
Dark element Dark element is offline
Angelo Gargarello
AKA: Angelo Gargarello
None #0005 (robocards)
Dark element will become famous soon enough
Send a message via MSN to Dark element
Question Dule batterys
Hello this is Angelo Gargarello the new caption of the Melvindale robocards team 5 just wanted to know if we where the first to have duel battery's on the robot with a back up pair. This system has a switch to switch from one set of battery's to the 2ed set just wondered if any one else did this yet
Melvindale Robocards team #5
Contact me at
theoldelement@gmail.com
Founder and Owner of The Old Element
Unread 23-05-2009, 09:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Dule batterys
We've run dual batteries in parallel for parades and such.
___________________
- Tennyson, Ulysses
Unread 23-05-2009, 09:36
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Dule batterys
(Assuming this is for non-competition use), why not just wire them in parallel?
You'd get the same 2x running time without the need for a switch.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-05-2009, 12:35
Re: Dule batterys
Originally Posted by artdutra04 View Post
...why not just wire them in parallel?
Batteries in parallel rarely work as well as you'd expect. Unless they are very well matched in condition, you'll usually end up with one battery discharging farther than it should before the other one has provided all its available energy.
Unread 23-05-2009, 17:06
Re: Dule batterys
Angelo,
Can you be more specific? Was this an FRC robot or something else? Were you using this for competition or show? FRC competition rules only allow one battery on a robot during competition. A second battery whether connected or not cannot be added to the robot.
Unread 23-05-2009, 19:58
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Re: Dule batterys
This couldn't have been used during competition, I don't think there's an inspector that could possibly miss TWO batteries on a robot.
The OP was a bit confusing, it sounds as though there are two separate sets of batteries, with each set consisting of two batteries wired in parallel. Is this the case?
In any case, I believe it's been done before, but I don't think it's incredibly common. It's still quite an interesting thing to do.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 23-05-2009, 23:24
Angelo Gargarello
Exclamation Re: Dule batterys
O.k this is just a for fun robot that is able to shoot ping-pong balls with compressed air using the first pneumatics compressor. What I have done is wired two battery's using a switch and a power board if needed i will take a picture to post for all of you that are interested in this project thank you for all the reply's
Contact me at
Unread 24-05-2009, 09:38
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Dule batterys
Sounds like a fun project. Can't wait to see the finished product.
___________________
- Tennyson, Ulysses
Unread 24-05-2009, 21:34
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Dule batterys
You may want to use one battery for the compressor, and the other for the electronics. The compressor will use the battery faster, and you can swap it out without shutting down the system.
Would love to see a picture.
Unread 28-05-2009, 18:49
Angelo Gargarello
Post Re: Dule batterys
thank you all for reading this post we have the robot up and running but today we found that some of the screws came out of the weel so we have to fix that. for all of you that where in robotics in 2005 we are reuseing that robot to make this robot if you would like the blue prints or picture/ movies of the bot email me at theoldelement@gmail.com I would love to hear from all of you
Contact me at
