Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 24-07-2009, 22:11
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Running Multiple Robots Using FMS Light...
We are trying to run multiple robots at once using the FMS light app and 1 router.
Seems pretty straight forward....
The problem is this, we have our wireless N router set to 10.16.25.4 as per the control system manual. The Wireless bridge on the robot is 10.16.25.1 and the CRio 10.16.25.2 the laptop that is running FMS is 10.16.25.6
If we just want to run our 1 robot using those settings FMS detects the DS and the Robot and runs just fine.
If we then go to hook up another CRio/DS into the network let just say 10.16.26.x (as if 1626 was also running their bot) FMS will not detect the DS or the CRio. If we change the router settings to match the second bot (10.16.26.x) it will work with that bot but will not detect the 10.16.25.x robot.
I have tried 2 different computers and the same problem on both...
Has anyone had any similar problems when trying to run multiple bots with FMS Light?
Anyone have any ideas as to why it will not run multiple bots at once?
I'm hoping its just something simple in the settings i overlooked like some IP not set correctly but ill take any help i can get.
Thanks!
Unread 24-07-2009, 23:32
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Running Multiple Robots Using FMS Light...
Thanks!
The only router and the bridge settings which matter are SSID and key.
The FMS light laptop should have the Ip 10.0.0.1.
You should also confirm you subnet mask on the PC is 255.0.0.0.
Eric Haskins KC9JVH
Unread 25-07-2009, 01:52
popo308's Avatar
AKA: Brent
So i should not let the router assign a DHCP address?
Originally Posted by Alan Anderson View Post
Change the netmask from 255.255.255.0 to be 255.0.0.0 instead, on both the computer and the router.
I assume this would be in the network setup page of the router? As in where you set the routers IP and other settings?
I'll give both of these things a try thanks for the help!
Unread 25-07-2009, 02:17
AKA: Eric Haskins
It doesn't matter if the DHCP server is enabled, but you do need to set a static IP address.
The correct settings should be, IP:10.0.0.1, Mask:255.0.0.0, Gateway:nothing, DNS servers:nothing
Here are instructions for XP. It's the same for Vista or 7, but you go to Network and Sharing center, then click Manage Network Connections, instead of opening Network connections.
To get your internet connection back after doing this, you will need to reselect Automatically Configure for both the IP address, and the DNS servers, in the IP or IPv4 configuration page.
The router's IP address will have no effect on this, and it may not even be possible to set it to anything less than 255.255.255.0.
Eric Haskins KC9JVH
Unread 26-07-2009, 02:22
popo308's Avatar
AKA: Brent
ya i found this out today but its ok it all worked in the end.
Thanks for the help
Change the netmask from 255.255.255.0 to be 255.0.0.0 instead, on both the computer and the router. If I understand the problem properly, that should do it.
Running Multiple Robots with the old Radios cbale2000 Technical Discussion 4 18-10-2007 19:40
Multiple Light Tracking with Distinct Light Boxes in EasyC hal Programming 1 19-02-2007 11:56
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
Using multiple robots at a display? Adam Richards Control System 5 02-04-2005 12:44
