Black FP Transmission Gears
Hey Cd,
I was looking for the specs on the gears that inside the "2009 Black FP KOP Transmission". I don't have access to the shop till next week, but a local team needed some plates machined out because their banebot planetaries finally kicked the bucket. All the gears were grinded and worn out, very kewl to see. I just needed the teeth count and the DP/module of each gear. Thanks, -RC Last edited by R.C. : 02-08-2009 at 21:42. |
Re: Black FP Transmission Gears
If you can wait until Tuesday evening and want to PM me an email address, I can send you a picture of the gears and you can count teeth. I'll also measure the OD of each gear and you can work backwards to the rest. Unfortunately, that's about the best I can do for you.
Ivan |
Thank you, -RC |
RC,
Here are the ODs of the gears and the tooth counts. As far as I acn tell, all of the gears in the FPs are the same regardless of color. The motor pinion may change. In the 2009 KoP I think the motor pinion had 16 teeth. The other option is 19 teeth. I don't have a 16 to measure, but the 19 tooth one measures .673" OD. Large OD Count Small OD Count Gear #1 2.283 72 teeth .870 25 teeth Gear #2 2.510 79 teeth .919 19 teeth Gear #3 2.634 62 teeth 1.300 12 teeth Gear #4 3.501 38 teeth Hope this helps, Ivan |
I'm pretty sure the FP gears are .8 Mod. (Based on my recollection that stock FP pinions are 31.75 DP, aka ~32 DP. Knowing DP = 25.4/Mod you can solve and get .8 Mod)
Pitch Diameter (mm) is Mod x Toothcount. So, for the 72T gear. PD (mm) = 72 * .8 = 57.6 mm PD (in) = 57.6 mm x (1 in / 25.4 mm) = 2.268 in (although I imagine it'd be more accurate to just enter the metric units into SW) I know you already know how to get C-C distances, so that should cover it for you. Last edited by AdamHeard : 04-08-2009 at 21:58. |
-RC |
#7
Adam is probably right about the .8 mod but that would only be correct for the pinion and the first 2 plastic gears. Second to third is a larger tooth and third to fourth is larger yet.
Here are some approximate CC distances measured from the one in my basement: Motor to #1 1.375 approximately #1 to #2 1.630 measured across the idler shafts and subtracted .375 #2 to #3 1.707 also measured across the shafts. #3 to #4 2.247 approximately because there isnt much to measure to on the last gear. Ivan Last edited by Ivan Helmrich : 04-08-2009 at 23:10. Reason: Added Pictures |
#8
I guess set up some formulas to get an approximate mod based on those C-C, then round the Mod to the nearest actual (it should be pretty darn close), then calc a precise C-C from that. |
| KOP transmission 2006- Pitch of Gears | neoshaakti | Motors | 1 | 05-02-2008 00:06 |
| Black & Decker Fisher Price Transmission | team222badbrad | General Forum | 11 | 18-03-2006 00:27 |
| Need info on gears inside drill transmission. | sanddrag | Motors | 7 | 14-04-2004 11:01 |
| power transmission NOT using gears/chains? | Frank(Aflak) | Technical Discussion | 37 | 21-05-2003 12:50 |
