6 wheel drive question
Hi. I'm trying various CAD designs for 6 wheel driven robots. This is a fun project for myself. Currently I have the design roughly CADed up with a slight center wheel offset. I was wondering whether the center of mass should be in line with the center wheels, or shifted behind the center wheel and what the pro's and con's of each would be.
Thanks. |
Re: 6 wheel drive question
By offset, do you mean that the center wheel is dropped down lower than the other wheels? If so, then the center off mass should be above the center wheels, so that the chassis can turn with only two wheels on the floor. If you moved the center of mass back, then it would favor the middle and back four wheels, meaning the front wheels wouldn't touch the ground as much.
DeepWater hit on exactly why you'd want the CG in the back (or front, depending on your objectives). Now, here is why you probably don't want it in the middle:
The rock is a lot harder to control. You have, in effect, an inverted pendulum with a barrier on each side. Balance it right, you're fine. Tap it lightly, or blow air on it, and it goes crazy. FRC robots get that kind of tapping from normal handling. Now, let's say that you want to pick up an object and put it somewhere with a reasonable degree of precision. You're rocking probably about 1/8" in either direction from dead horizontal, due to the "height" of the drop with relation to the end wheels. So you have to allow for a 1/4" variation in location, just in normal rocking--and that's not including the multiple other places that you could get an error. So you really don't have a huge amount of precision, while by moving the CG back about a foot, you still have that amount of variation, but you know that it will be momentary at worst, and you'll end up back in your "normal" position. |
Look up 6WD, as there are a ton of great posts related to this material. From a robot dynamics standpoint, it depends on the behaviour you want out of your robot, the amount of drop, and the rigidity of the chassis.
Read through the other posts and see if they help. |
#7
What DeepWater was basically saying is that due to manipulator's built to play certain games, you want a certain CoG for the entire frame. Depending on the placement, weight, and maneuvers (rotational, lateral,etc.) manipulators require, you would want the robot to essentially "tip" a certain way. The physics of the manipulator, height, and weight of the entire machine all come into play.
#8
Yup, by offset I meant dropped/lowered relative to the outer wheels. So the design would be game dependent in an FRC situation, but if it was say for a slightly more general purpose, would adding more weight towards the rear wheels, as a few of you have suggested, make more sense?
Thanks for the quick responses! |
#9
Another thing to consider...
Dropping the center wheel 1/8" - 3/18" works very well. However, there may be designs that are more efficient if all 3 wheels on a side are at the same height (same bearing plate is being used, etc.). If this is the situation, instead of dropping the center wheel, you can make the center wheel have a slightly larger diameter and still achieve this needed "rock" dynamic that enables a robot to turn on the center pivot. In order to do this, you can make your center wheel have a slightly thicker tread... or make your outer wheels have slightly thinner tread thicknesses. Have fun, Andy B. |
#11
http://www.chiefdelphi.com/media/photos/29748 http://www.chiefdelphi.com/media/photos/26122 |
#13
Images would help a lot and we could offer suggestions from there.
-RC |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| Question About 4-Wheel Drive | Pat McCarthy | Technical Discussion | 19 | 26-06-2005 23:38 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| Four wheel drive question | haverfordfords | General Forum | 25 | 25-01-2005 23:24 |
