Go to Post It is proper to have a disagreement, but it is improper to be disrespectful. - Bill Moore [more]
Unread 06-08-2009, 17:17
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
pic: Monocoque Treads
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: Monocoque Treads
Wow, very nice render.
Excuse my ignorance, but how do you get power to the tread itself?
Good stuff though, I like it.
Unread 06-08-2009, 17:27
That looks amazing Andy.
I'll definitely have to take a crack at replicating that next week. RC's thinking the same thing right now probably.
Unread 06-08-2009, 17:32
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
WOW Akash, you read my mind But Andy, that looks SICK. ME LIKEEEE.
-RC
R.C.
MadTown Robotics Team 1323
Unread 06-08-2009, 17:42
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
That is an absolutely beautiful render. I too am curious about how the tread is driven though.
Mentor 2415
Unread 06-08-2009, 17:58
It looks like the drive system is in the middle, where what seems to be an axle pokes out from a bearing. I'd say right above that is where the drive goes. Am I correct?
Unread 06-08-2009, 18:45
AndyB's Avatar
AKA: Andy Burchardt
Yes Eric, you are correct. If you look closely, a bit of shaft is sticking out of the middle into the bay of the frame. I think my original intentions were to use a Gen 2 AM shifter but the shaft is standard 1/2" keyed, so direct drive would be possible as well.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 06-08-2009, 21:53
What's the wall thickness of the various rails and the electronics pan?
Unread 06-08-2009, 23:20
AndyB's Avatar
AKA: Andy Burchardt
I'm not 100% sure on that. I found the cad file of the design and noticed that the wall thickness was .1in, but that's hardly accurate. In a design like this, I'd probably use .08-.09" for 6061 aluminum or .03-.05" for some sort of galvanized steel. I'd probably use sheet steel just because it's readily available to us.
I've never actually worked with sheet steel within FIRST robotics. I tried doing some research on it but couldn't find much in terms of second hand experience. I've used chromoly steel back when I was with 269 but the properties of chromoly extrusion and galvanized sheet steel are probably pretty different as well. I've heard the number 3x the weight/strength when compared to aluminum but I have no clue if that's correct or not. It was with chromoly extrusion compared to aluminum extrusion which is why we could use .035" wall thickness extrusion.
So to answer your question Akash, .08-.09" Aluminum or .03-.05" Steel.
Something interesting to point out now that I'm looking at the design more up close is how the rollers are set up. There are no crossbars inside the tread modules to add support. At least not any supports designed solely as crossbars... the axles for each roller are dead and the UHMW or UDPE rollers spin freely on them. This way, the roller acts as a crossbar support as well.
Unread 06-08-2009, 23:59
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is online now
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
That kind of reminds me of the 2006 robots that NiagaraFIRST built.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 07-08-2009, 00:03
Its also pretty similar to the frame 25 uses on their beautiful drivetrains.
Unread 07-08-2009, 00:10
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
One of the general rules of thumb when working with sheet metal is that aluminum sheets need to be 40% thicker to achieve similar structural properties. Since .080 to .090 wall thickness aluminum sounds about right for a well designed FRC frame, the equivalent steel thickness would be a little higher than your estimates, in the .060 to .063 range.
Depending on the actual alloy used however, these figures will vary.
Art Dutra IV
世上无难事,只怕有心人.
pic: uber cheap tank treads for vex colin340 Extra Discussion 2 20-02-2008 20:06
Unibody/Monocoque Construction Sam N. Technical Discussion 26 18-06-2007 15:09
pic: 25-match-old andymark treads Bongle Extra Discussion 3 02-04-2006 01:07
pic: Team 1718 Treads Craig Roys Robot Showcase 11 13-02-2006 12:40
Treads 101 Sachiel7 Technical Discussion 2 08-01-2006 18:19
