Go to Post The propagation of the idea of making FIRST into a perfectly fair competition is just silly. - Andy Baker [more]
Go Back   Chief Delphi > Technical > CAD
Unread 17-09-2009, 17:35
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Physical Limits In Assemblies
Is it possible to create physical limits between parts in assembly files so that when making them move for display purposes they don't bug out and pass through other solid objects?
Unread 17-09-2009, 19:54
Re: Physical Limits In Assemblies
Do you mean like setting distance limits/spacing/locking objects? If so, yes, in Solidworks at least.
Unread 17-09-2009, 20:05
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Like this? http://www.youtube.com/watch?v=P6V-qlwqg6k
Yeah it's possible.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-09-2009, 20:08
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Actually I am working in Inventor 08, and yes I am wondering about collision detection like in Solidworks but my license is expired for that, I was wondering if you can do the same in Inventor.
Unread 17-09-2009, 20:48
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Its not collision detection but there is a way to do what your talking about I believe see the attached picture for the constant
Unread 18-09-2009, 06:32
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
Here is how I check for collisions using inventor 2010 in my assemblies:
I set up a drive constraint on my parts and the check the box for collision detection. It will stop the movement of your assembly and show you where you have material going through. It is under more options button (>>) to see this box to check.
If you want to do this on a non-driven feature. Under the inspect tab you will find analyze interference.
Allison
Unread 18-09-2009, 11:01
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Thank you all for the responses, I have found what I was looking for here. I figures out the Dynamic environment last night, but I was looking for a live reaction. I used the tutorial and found the "Contact Set" feature.
Again thank you for any help that was offered.
Unread 18-09-2009, 16:10
pmax's Avatar
pmax pmax is offline
AKA: Peter Maxfield
pmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to allpmax is a name known to all
Howdy
It looks like you found what you needed using Contact sets in Assembly.
We are working on Constraint Limits in house for a future release. Note you can also "fake" a limit using Transitional constraints, as Jeff 801 pointed out. It is not ideal, but for sliders like a hydraulic cylinder, it does the trick.
-Pete
Autodesk
www.autodesk.com/first
[OCCRA]: Rule #RB6 - Physical Constraints SWIM OCCRA Q&A 1 12-09-2008 21:17
Simulating Motion with Physical Dynamics Madison SolidWorks 5 08-02-2007 12:19
Putting assemblies into other assemblies Crewmmbr21 Inventor 3 10-02-2005 16:15
Mental and physical aspects of Competition Swampdude General Forum 11 05-01-2005 12:54
Physical matches archiver 1999 31 23-06-2002 23:14
