Autodesk - .stp file to .iam
So I wanted an autodesk assembly file of the AM shifter, and I found this thread:
http://www.chiefdelphi.com/forums/sh...ter+autode sk I would have posted there, but it's closed. So, here's the problem. I followed the instructions, and I opened the .stp file, and it worked. As the old post said, nothing was constrained, but I grounded everything and saved it as a .iam file. This all worked fine, but when I placed the AM Shifter assembly into another assembly, after i constrained it down, Autodesk froze. I did this two more times and the same thing happened. I've had autodesk 2009 freeze a couple of times over the year that I've had it, but never 3 times in a row, so I guessing it has something to do with the converted .stp file. Anyone have this problem? Any ideas? Thanks, -Seth |
Re: Autodesk - .stp file to .iam
Wow, thats very odd indeed...
When you say you did this 2 more times... does that mean placing it into an assembly? or does that mean re-downloading that from AM and converting it from a STEP file? I'd try that last one... and if that doesn't work try rebooting your pc. Sometimes that will fix the issue between autodesk and windows. |
Rebooted, re-downloaded the files and it happened two more times.
This is very annoying... |
Wow that really stinks dude...
Try this CAD Site. my bud RC put this together with help of a ton of other people. This has the files for inventor.. constrained and everything. It has everything you'd need I'm sure. http://team1323.com/cad/index.html |
Thanks alot, I should get around to uploading some files there.
| Autodesk Inventor Design Competition: File naming | pmax | Inventor | 2 | 08-01-2009 12:04 |
| IGES and STP file modification | TomBW | CAD | 3 | 31-01-2008 15:11 |
| How to use the data obtain in one C file to another C file? | tommy_chai | Programming | 8 | 11-01-2008 02:17 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| Autodesk Inventor -> 3ds Max (File Format) | Adrian Wong | Inventor | 1 | 22-01-2002 23:06 |
