Go to Post We don't want "The Flame Heard 'Round the World"... - Andrew Blair [more]
Unread 24-10-2009, 21:56
af4ex af4ex is offline
AKA: John
FTC #2841 (Conspicuous Ninja)
af4ex is an unknown quantity at this point
[FTC]: Need BlueTooth Help
[I posted this originally under 'Programming' but didn't get much response (maybe wrong forum for this problem) so trying again here.]
We cannot connect to our brick via BlueTooth using RobotC 1.93. USB connect works OK and we can download the new Firmware 7.83 OK. But when we try to connect via BT, we get error message "No 'NXT' bricks could be found" immediately after the Passkey Enabling. Deleting the connection in the BT Devices list and starting over doesn't help. We've tried this on 3 different computers with same results.
We had no problems at all with the previous RobotC 1.4 using the same BT and brick. In fact, the problem started immediately after we switched to 1.93 two weeks ago (we got a late start this season, our second year).
We're starting to suspect a software bug in RobotC 1.93. Has anyone else had a similar problem? Can anyone suggest a fix?
Thanks,
John Day
Mentor for Team #2841
West Shore Jr/Sr HS
Melbourne, Florida
Unread 26-10-2009, 22:51
AKA: John
Re: [FTC]: Need BlueTooth Help
Connect problem has been solved. Seems to have been a bad NXT brick. We located another brick and, using the same BT and computer, it connected perfectly on the first try, without giving us the dreaded "No bricks could be found" message.
Will try to get the old brick replaced under warranty.
John Day
West Shore Jr/Sr HS
Melbourne, Florida
[FTC]: Bluetooth Problem with LabView/FTC Controller Station James Dowd FIRST Tech Challenge 8 27-10-2009 10:40
Need Bluetooth help af4ex Programming 4 25-10-2009 19:39
[FTC]: Bluetooth nate15810 FIRST Tech Challenge 6 04-03-2009 16:07
[FTC]: Bluetooth lag? Nick 568 FIRST Tech Challenge 5 12-02-2009 07:49
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
