Go to Post This just in: moving sideways still a colossal waste of time. - TheOtherGuy [more]
Unread 30-10-2009, 18:42
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: Molding Plastics
I would like to mold the plastics, what is the best way to mold the plastic materials that are the allowable materials?
I don't have much equipment, but will be seeking out resources to mold the plastic once I find the best method.
Thanks.
Unread 30-10-2009, 20:52
Re: [FTC]: Molding Plastics
With the polycarbonate sheeting, the most common way used in FTC so far has been to use a heat gun (pretty cheap at Lowes) and form the plastic around something with a similar diameter/curvature/what have you. Without heat, in a regular bender, you should be fine with thicknesses of sheeting up to .125".
Unread 30-10-2009, 21:00
kevincrispie's Avatar
kevincrispie kevincrispie is offline
FRC #0971 (Spartan Robotics)
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
You could use a heat gun and lexand
Unread 30-10-2009, 21:01
sorry, it is Lexan, another name for Polycarbonate sheeting.
Unread 31-10-2009, 01:25
FTC #0071
Most of what I have read reports it is quite difficult to mold lexan/polycarbonate with a heat gun. they talk about heat ovens and such. any other tips or tricks out there for molding the polycarbonate?
Thanks.
Unread 31-10-2009, 13:12
There is such thing as I lexan bender I think, its just a manual thing, though I'm not completely sure how it works
Unread 31-10-2009, 15:55
dtengineering's Avatar
AKA: Jason Brett
Lexan bends really nicely in sheet metal working tools, such as the box and pan brake. If your school has a metal shop... give it a try on a practice piece.
If you are wanting compound curves, however, you might want to try vacuum forming. There is a very extensive write up here http://support.knowlton.ohio-state.e...acuumGuide.pdf But it is actually fairly easy to build your own small vacuum former.
Just google vacuum forming diy for some ideas.
Jason
Unread 31-10-2009, 23:35
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
This is probably off topic from what you are looking for, but nonetheless it's pretty cool and could be useful for some.
DIY Plastic Vacuum Mold
Molding Custom Wheels? Akash Rastogi CAD 15 07-11-2010 12:43
[FTC]: Sources for FTC plastics. PhilBot FIRST Tech Challenge 1 22-10-2009 23:26
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
Machining plastics with CNC Ben Mitchell Technical Discussion 14 13-03-2007 14:01
I need help with plastics mechanicalbrain Technical Discussion 13 14-06-2006 11:15
