Go to Post looks like he was getting ready for a sprint! be careful chuck, its only like 2 feet from the line to the controls... - vivek16 [more]
Unread 03-12-2009, 11:55
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
pic: Modified/Integrated Transmission
Unread 03-12-2009, 12:01
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: Modified/Integrated Transmission
The 20DP, 14.5PA steel AM Toughbox gears should be more than capable of transmitting that much torque (and much more) before giving you any trouble. Several teams have used similar arrangements in the past.
My only other thought is that I'm not sure if the relatively meager weight savings of dogging the inner plate like that are worth the decrease in strength.
Good job!
Unread 03-12-2009, 12:05
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Make sure you keep it well lubricated, that is the only way I have ever seen a toughbox shredded.
This is some sort of exploded view (or has an inner frame rail with visibility off), right?
As much as pocketing the plate is probably a waste of time and resources, it looks pretty darn good.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 03-12-2009, 12:08
Forgive my ignorance*, but what is the white bit on top of the CIMs? A third motor or a sensor?
*I have the flu and everything is dancing. You'd think the swine flu would make me as smart as a Pig Farmer, but I have no Andy Baker Powers.
Unread 03-12-2009, 12:15
Joining the 900 Meme Team
FRC #0079
Third Motor, most likely a FP motor through a AM Planetary, I think it just rendered wonky.
Oink Oink Get Better Soon!
Unread 03-12-2009, 12:30
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
If the frame flexes slightly from an impact (unlikely with bumpers on, but still) what is the probability of the gearboxes failure?
And yes, that is a FP through the new AM Planetary casing (saves .2lb!). I do miss the blue anodized and red anodized casings though... maybe Andy still has some laying around. I left the inner frame visibility off so one can actually see the two stages (mostly). In the animation, the inner frame is visible but I removed visibility on one of the standoffs holding the mounting plate away from the inside plate.
Unread 03-12-2009, 12:37
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Looks cool.
Handy tip,:
Remember that if you use the 14t CIM gear from AM you will not be able to pull the motor and pinion assembly through the CIM pilot hole without taking it apart.
You could make the center CIM mount hole larger than the pinion OD(.9" or so), then tighten your tolerance on the bolt holes to give you some alignment....this way you can disassemble the motors without having to remove the pinions.
Or just use the 12t pinion that is used on SuperShifter.
Good luck.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 03-12-2009, 12:55
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Thanks for the input ajlapp, I think we'll take the advice to allow us to pull the motors out without banging at em with a flathead first.
Here is a picture of the mounting plate. Things circled in red are motor mounts. Things circled in purple are where the spacers go. The bit circled in lime-green are the two reductions for the gearbox.
http://s169.photobucket.com/albums/u...ntingplate.png
We ended up keeping the mounting holes the same dimensions as the TB so if things go south we can just bolt a pre-assembled toughbox on and keep on rolling.
Unread 03-12-2009, 15:33
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
As long as both the frame and the transmission plate aren't too flexible and have a small amount of "loose" tolerance, there shouldn't be any problems. Team 228 had a similar design last year, taking the guts out of the Toughbox (except with a 12t CIM pinion gear instead of the 14t) and building it into the chassis with the output shaft of the gearbox direct driving the rear wheels of the robot. Our main competition robot used a single 0.125" CNC sheet metal plate without standoffs for the transmission, and the practice robot used a 0.1875" CNC-milled aluminum plate with standoffs. Both performed equally well, with the competition robot running an entire season (six competitions) and countless hours on the practice robot without any problems. Here's some photos:
Competition robot:
Practice robot (bottom view):
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-12-2009, 17:48
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
We did something similar in 2007 with the big CIM, small CIM, and FP motors and had no problems.
http://www.chiefdelphi.com/media/photos/28837
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 04-12-2009, 00:26
CraigHickman
Posts: n/a
I would highly suggest against pocketing your motor mounting plate like that. Not for strength concerns, but for cost and time. The weight savings simply aren't worth the headache.
That being said, Nice design! Ought to make everything nice and integrated. If you can figure out a system to make each side of the drive system modular (IE GRT in 2007), it would add to the system's robustness and quick-changeability during competition.
I'm still waiting for a team that can pull of Nascar speed pit stops for battery and drive changes. It'll be cool to see a team rush into the put, drop the entire robot base (drive+battery), latch a new one on, and rush off. You know, I think my CAD setup is calling me...
Unread 04-12-2009, 00:31
AdamHeard's Avatar
Lead Mentor
I wouldn't say this is a universal truth. Assuming they are getting plates CNC'd anyway, it's really not a headache at all, and not a lot of additional run time.
I know last year we took out about 1.5 lbs total from our gearbox plates, even if was half a pound, that could be a big deal.
And even if the plates aren't being CNC'd, pocketing can be done by hand or on a manual relatively easily, and an hour of work for half of pound of weight is a no brainer for any team (there are an awful lot of hours in the season...).
Unread 04-12-2009, 02:34
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Each drive assembly contains the gearbox, two sideplates bolted together with spacers, and the wheel assembly. Thusly with all assemblies added together, you get 1 drive assembly (1/2 of the bot, 2 wheels). Each drive assembly bolts to 3 1"x1" 8020 bars that go across the bot. So technically, if we had backup full drive assemblies made, we could fully change out half of our drive train by removing 3 bolts, sliding the drive assembly off the 8020, putting the new assembly on, and bolting the drive assembly back to the 8020 crossbeams. I'd reckon with a pre-made backup, it could be a 2 minute job (Or, if you wanted a super-speed run nascar style, a power drill + bot on a crate + a guy holding the assembly beside you, could be a 20 second job). I think this older picture of our drive assembly shows what i'm talking about nicely, along with the picture of our 2009 bot. We used this same 8020 crossbeam design in 2007 and 2009 and they worked excellently
Unread 04-12-2009, 12:06
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Competition robot:
Off-Topic:
Art, that is some BEAUTIFUL work. I love the sheet-metal work you guys did. If only it was powdercoated black!
-John
/Off-Topic
Unread 04-12-2009, 12:47
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Huh, just for kicks and giggles I asked a sponsor of our team if they could waterjet out this plate and what do you know, 12 hour turn-around from sending the DXF and getting it made. I'm so very happy right now.
Thoughts?
pic: Modified Andy Mark 2 speed gearbox sam shawe Extra Discussion 3 29-04-2011 00:22
pic: 1213 GROVES modified tough box groves Extra Discussion 12 09-02-2009 10:30
pic: re-modified 6wd spc295 Extra Discussion 15 19-11-2008 15:14
Running Inventor on an eMachines Celeron with integrated graphics sanddrag Inventor 4 25-11-2005 08:42
pic: A nikko RC car, modified Andy A. Extra Discussion 11 20-03-2005 11:59
