Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 03-12-2009, 15:56
cougarbytes cougarbytes is offline
FTC #3506
cougarbytes is an unknown quantity at this point
[FTC]: Help with LabView and variables?
In LabView, we are attempting to make our servos move in increments for the duration that we press a button. However, with our current code, we are able to press a button, and upon that press, have our servo move to a set position. We would like to know how to "store" a variable and add a set number to it so that it moves the servo up/down in our set increment as long as our button is still pressed.
We are a rookie team, and have never used LabView before. All tips and suggestions are welcome!
Unread 29-12-2009, 15:14
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Re: [FTC]: Help with LabView and variables?
Here is an example i drew up for you guys. To make it go reverse, just put another case structure in there. I am with FRC, but the logic should be the same.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 29-12-2009, 15:57
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
I have also created an example and posted it the NI FTC Community page.
Open and Close Servo Incrementally with Game Pad Buttons
This example shows how you can use two game-pad buttons to incrementally increase and decrease the position value of a servo. The example also shows an efficient method of using a case structure with the FTC Read Buttons VI rather than using nested case structures.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
HELP!!! BOOLEAN VARIABLES IN LABVIEW PRAWG Programming 2 07-02-2009 18:44
[FTC]: Variables in labview wilsonmw04 FIRST Tech Challenge 2 23-11-2008 08:57
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
First problems with FTC and Labview PhilBot National Instruments LabVIEW and Data Acquisition 0 10-09-2008 20:21
Labview dashboard and multiple variables Joe Ross LabView and Data Acquisition 2 15-03-2006 21:55
