Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 08-01-2010, 20:17
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Git on Windows vs Git on Unix/Linux
Okay, so I've been trying out Git for a week or two, and it's taken me a bit to get the hang of it (because I'm not used to operating from the command line). However, I purchased Pro Git, because I was looking it up online so often, and have been fairly good since.
However, now I'm trying it on Windows. I personally use a MacBook, and run Windows in VMware Fusion, so I had been running Git from the Unix terminal. However, in order to make sure the programming team can use it, I need to test it on Windows. I chose msysgit, rather than cygwin, because it looked simpler to install and use.
So I install it and get it running, and cd to my repository, and run git status.
And it tells me every single file in my repository has been modified.
(I haven't tried committing, because I don't want to corrupt my repository.)
So I go back to the Unix terminal, and try git status, and it tells me there have been no changes.
Will this happen every time I switch between Windows and Unix? Or is there something wrong with my install?
Would I be better off with cygwin?
-- Marshal Horn
Unread 08-01-2010, 20:37
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Git on Windows vs Git on Unix/Linux
I just exported a git repo from my Windows box to my Ubuntu 9.10. Works perfect for me, probably your config... Git has an IRC channel...
#git
irc.freenode.net
After all Git was created by Linus Torvalds which is one of the core fathers of Linux - I would think it would work better on Linux.
Unread 08-01-2010, 21:11
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
most likely \r\n vs \n issues
use Notepad++ (or equiv) and see if it is unix or dos/windows encoded
My expertise is SVN (and subclipse, no Command line needed) but you might want to check the mode: text or binary. It needs to be text or \n will not be translated to \r\n automatically (and vice versa and same for \r mac)
Watchdog.Kill();
Unread 08-01-2010, 21:16
My guess is that it is because of the difference in windows / unix line endings and automatic conversions because of that difference. See http://code.google.com/p/msysgit/issues/detail?id=271
Unread 09-01-2010, 09:31
Nibbles Nibbles is offline
Interstellar Hitchhiker
AKA: Austin Wright
FRC #0498 (Cobra Commanders)
Nibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really niceNibbles is just really nice
If that's the case the relevant setting would be core.autocrlf = true
Help standardize match data! Use the XML interchange format. (Specification page)
AAA_awright on Freenode IRC chat. (Join us at ##FRC on chat.freenode.net, or in your browser)
Unread 10-01-2010, 00:25
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
I've been trying that, and it doesn't seem to make a big difference.
So, I tried committing it, and we'll see if it creates any problems with LabVIEW.
-- Marshal Horn
Why you should care about version control, and why I suggest git fixermark Programming 23 21-01-2010 09:57
C and LabView version control with Git Nibbles NI LabVIEW 31 17-01-2010 19:22
git for source code management? d235j Programming 2 08-01-2009 22:59
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
