What is the base dimension of the bump in terms of length [trapezoid]
1/2(12+b2)h= area What is b2? |
Re: Dimension of Bump
Oh people, please read the manual, but the bump is 12" wide at the top, and approx. 32.5" wide at the bottom, creating a approx. 45 degree angle.
I don't remember that actually being in the manual. Get game-specific drawing GE-10047 if you want the drawing (it is indeed 33.5 inches).
You might check out http://usfirst.org/roboticsprograms/....aspx?id=16097
Not only will it have the dimension you seek, it has all the field dimensions that you need to build a version for your team. Once you look at the drawings, of course. |
I just figured out the angle of is 45 degrees, therefor the base length is 36"
Correct, I was quoting the size of the support rib, which is shown in the drawing.
#7
That doesn't seem to be right. Did you take into account the portion that is "vertical"? The drawing shows that the its profile is that of a hexagon. The trapezoid is raised up 2.1875 inches above the ground. The height of the actual trapezoid seems to be 10.25" (excluding the portion below it), with a specified angle in the drawing of 10.25, giving a total height of 12.4735 inches.
#8
When I look at drawing GE-10047.pdf, the height of the rib is 12 7/16". When you add the 3/4" plywood on top that makes the height of the bump 13 3/16" without the carpet. Does this seem right? I thought the bump should have been much closer to 12".
| Trailer dimension contradictions? | Stephanie.S | Technical Discussion | 0 | 14-01-2009 15:21 |
| 1/2" bump in field? | Doug G | Technical Discussion | 8 | 30-01-2008 12:41 |
| <G18> - Maximum dimension | StevenB | Rules/Strategy | 2 | 09-01-2008 20:48 |
| Line or Bump? | Swathi | General Forum | 2 | 05-01-2008 16:08 |
