Go to Post I'm somewhat fond of saying, if your robot dosen't weigh 119.99 pounds, you forgot something. - Francis-134 [more]
Unread 10-01-2010, 19:40
phil-1302's Avatar
phil-1302 phil-1302 is offline
AKA: Phil
FRC #1302 (Revolution Robotics)
Team Role: Driver
phil-1302 will become famous soon enough
NETBOOK HELP!
Hello, well today our team opened up the KOP and took out the net book. Unfortunately the net book was started up to be tested when the KOP was picked up from FIRST. Whoever tested the net book canceled out of the set-up wizard. Any suggestions on what to do? Any help would be great!
Phil.
Team 1302
Unread 10-01-2010, 20:12
Re: NETBOOK HELP!
Could you describe what screen you're at or what it does? It's more likely that someone can help you if you describe everything in detail rather then assuming that people know what happens when you cancel the setup wizard.
Unread 10-01-2010, 20:35
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: NETBOOK HELP!
Worst case you can use the provided Recovery USB key.
Unread 10-01-2010, 21:29
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: NETBOOK HELP!
yeah if the USB key is the original image then just use that.
Unread 10-01-2010, 21:35
phil-1302's Avatar
AKA: Phil
Team Role: Driver
Re: NETBOOK HELP!
Thanks!
Unread 10-01-2010, 22:52
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: NETBOOK HELP!
You just need to change your computer name to TeamXXXX
Right click on my computer, go to properties, go to the computer name tab, and then click on the (bottom i believe button) to change your computer name.
Thats all that setup did.
Unread 10-01-2010, 23:03
phil-1302's Avatar
AKA: Phil
Team Role: Driver
Re: NETBOOK HELP!
THANKS!
Unread 12-01-2010, 20:24
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
penguain is an unknown quantity at this point
Re: NETBOOK HELP!
do you know the path to the wizard .exe file?
2007 Greater Kansas City Regional Champions
2008 Greater Kansas City Regional Finalists
Unread 12-01-2010, 23:01
Re: NETBOOK HELP!
What is the wizard you are looking for?
Greg McKaskle
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station 2010 - Netbook? Greg Marra Control System 16 09-07-2009 19:48
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
