Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 01-11-2010, 09:18 PM
alexhennning alexhennning is offline
FRC #0348
alexhennning is an unknown quantity at this point
Eclipse
I've been working on the eclipse plugin, it's not quite done I still have to write the code for loading it onto the robot but the rest is done. I'll probably be posting the code I have done (and the rest if I finish it) sometime this week. So, if your teams interested in using eclipse in place of netbeans, that should be possible shortly. More information: http://forums.usfirst.org/showthread.php?t=13487
Unread 01-13-2010, 09:29 PM
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Re: Eclipse
How are you doing the deploy?
If you can figure out how to get to call an ant target, then you should call the deploy target as part of the project.
Note, if you wanted to, I am sure we could get Brad to start a project on firstforge and we could have people participate in helping getting this done.
Programming in Eclipse GGCO Programming 2 04-25-2008 11:18 PM
Eclipse Development Astronouth7303 Programming 39 12-16-2007 02:52 AM
"Full screen mode" in Eclipse/Easy Eclipse Kelly Programming 0 07-15-2007 04:37 PM
using eclipse dasRatsel Programming 82 01-02-2006 01:20 PM
