Go to Post Nothing's more memorable than giving someone a foul mouthed clown :cool: - Dave Scheck [more]
Unread 11-01-2010, 22:29
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Is this possible in LabView?(Setting Pressure)
This is a more of a "Is this possible?" thread. My team has drawn up a plan for a kicking device. They want it to have three pressure settings and to have that pressure set by pushing an assigned button. The three settings would be like a low, medium, and high pressure. My question is: Is this possible to do in labview? It would be 3 buttons that would set the pressure to low,medium,and high. The pressure would also have to back forth from like high to medium back to high. If it is possible, how would I go about starting this code? Thanks!
Edit : if three pressures can't be set, can three "positions" be set to stop at or some other way?
Unread 11-01-2010, 22:33
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Is this possible in LabView?(Setting Pressure)
Coding is only one part of this task to consider. You have to find a way to actually provide the different pressures to the cylinder before you know how to program it.
See this thread for some possible ideas
Unread 11-01-2010, 22:37
Thanks for the speedy response! I will look into the thread.
Unread 12-01-2010, 14:53
elmer_fud elmer_fud is offline
mentor/code monkey
FRC #2859
elmer_fud is an unknown quantity at this point
For controlling the pressure I would just use the joystick buttons. There is a VI in Labview that you can use to easily access the buttons on the joysticks.
As for the pressure what about limiting the flow of air rather than limiting the pressure. You could use 3 different orifices (think washers with different sized holes) on 3 different valves.
Unread 12-01-2010, 20:59
ASTDan ASTDan is offline
ASTDan is an unknown quantity at this point
Anything is possible...
You might look at a controllable regulator
You could send the signal to the pressure controller and have whatever amount of pressure you would need.
Unread 12-01-2010, 23:16
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Talking Re: Is this possible in LabView?(Setting Pressure)
If you need three different pressure settings here's what you do. You have three regulators on different lines leading from the air tank to a junction at the piston. Downstream of each regulator, you have a different solenoid. Wire up your joystick in labview so that the buttons on your joystick can fire each of the three solenoids independently. This gives you three different pressure settings and some very easy labview code to write.
My team worked on this idea today, not just me.
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 13-01-2010, 00:40
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
That's a lot of weight... But I actually don't have a good idea of how I would tackle the problem...
Keehun
Team 2502
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 13-01-2010, 01:52
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
If you are trying to change the speed of your kicker, you can keep the pressure setting the same and change the flow. You can valve different flow controls to deliver different flow rates thus different kick speeds. Just remember to control the out flow and not the in flow to the cylinder so you don't starve it of air. Flow controls are a bit lighter than additional regulators.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
POSSIBLE LABVIEW BUG EncodersRUS NI LabVIEW 1 11-01-2010 23:22
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Is this possible? (Gears and chains) TJ4nier Technical Discussion 7 20-01-2007 23:06
Is this possible? WhiteTiger Control System 2 08-02-2005 16:53
TI Pressure Sensor this year? kmcclary Pneumatics 1 20-01-2005 20:53
