Go to Post Learn the subjects that interest you, but at the same time know how it relate to real life situations, and how it is applied. - Ryan Dognaux [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 11-01-2010, 23:38
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Call up Pro/E files in SolidWorks
As a SolidWorks CAD designer, I want to remind (inform) people that most of the part files available for Pro/E will open in SolidWorks just fine. No need to spend time creating most of the 3D parts.
Just download the Pro/E files (from FIRST's site) to your computer, open SolidWorks, and do a file open and ensure it is looking for *.* Then you will see all of the Pro/E files. It will do a quick file conversion. It will ask for features or body. Features is more robust but usually not needed. I suggest "body" unless you plan on changing a CAD file. For purchased, off the shelf, parts we usually have no need to change dimensions.
Troy
Mentor--SolidWorks user since 2003--CSWA
Unread 12-01-2010, 19:29
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: Call up Pro/E files in SolidWorks
These imported parts may or may not come in with materials.
You can set materials by right-click on the Materials tab in the FeatureManager.
You can also set the exact weight in Tools, MassProperties.
Watch out for little descrepencies with imported geometery, when I imported the AM0204, and set material to Al 5052 I got 1.2 pounds but Andy Mark states it is 1.4. Use a scale for the exact weight.
On thing nice about imported geometry, it makes your assembly model very light weight. Saves time.
Dont spend your time recreating purchased kit parts - you have an arm to design!
Marie
Solidworks KOP files nittemare SolidWorks 7 15-01-2012 18:00
Is it possible too import the Auodesk Files to Solidworks? vmuralidharan Inventor 2 10-01-2009 14:41
Solidworks to Pro/E file conversion Peter Matteson SolidWorks 1 04-08-2006 14:07
Inventor / solidworks / Pro E Andrew Schuetze Inventor 11 19-06-2006 10:27
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
