Go to Post Lucky breaks and trying to minimize failures or moments of retardedness are what these games are all about, like any sport. - Bill Gold [more]
Unread 12-01-2010, 10:13
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Grappling hook?
Is it possible to have a hook shoot up at an angle with strong rope attached and latch on to the tower (assuming its in the height limits). then is it possible to reel the rope in?
This is just an idea our team has had and im wondering if it can be accomplished.
Unread 12-01-2010, 10:25
vg674's Avatar
vg674 vg674 is offline
FRC #0118 (Robonauts)
vg674 is an unknown quantity at this point
Re: Grappling hook?
The only problem I would see is with the entanglement of robots or being hazardous to people. Rules <R03> to <R06> seem to say that it is essentially too dangerous to do so, and understandably so. I can only imagine a grappling hook shooting the wrong way and ramming into players or refs or destroying the field... not so great. Good idea though!
The board is a mirror of the mind of the players as the moments pass. When a master studies the record of a game he can tell at what point greed overtook the pupil, when he became tired, when he fell into stupidity, and when the maid came by with tea.
- Anonymous Go player
Unread 12-01-2010, 10:26
Sean Raia's Avatar
Re: Grappling hook?
Yeah that was one of our concerns, and i doubt we will be using the grappling hook idea. But would it be possible to shoot the grappling hook out or reel the rope in and lift a 120 pound robot in the first place?
I want to know weather or not we should consider it as a plausible idea.
Unread 12-01-2010, 10:36
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Re: Grappling hook?
http://www.chiefdelphi.com/forums/ne...reply&p=897181
Originally Posted by Kevin Sevcik View Post
To bring a little more "training" to the discussion... you just have to look at the maximum power of your motors to determine the absolute fastest you can get a robot up.
Power = Work / Time
Work = Force * Distance
so
Power = Force * Distance / Time
or
Power = Force * Speeeeeeeed
The CIM motors max out at 343W = 252 lbf*ft/s
So the fastest an optimally geared CIM will lift a bot is about 1.5 ft/s. Or you lift in about a second.
Mind, this assume you're instantly at the max power point, no friction losses, spherical chickens, the works. But, lifting your robot 20" in, say, 5 seconds is easily doable if you gear it right. The gearing it right being key. Max power occurs at 1/2 stall torque. But I'd really aim for 1/4 - 1/3 stall torque for your full load, for safety and losses and all that.
vg674's Avatar
Re: Grappling hook?
With the right material, I would say that that wouldn't be a problem at all. There are many ways to lessen the strain, and I think it would be quite easily possible to engineer a way, be it pulleys or a fancy combination of motors to use a grappling hook to hang from the bar, and even great in the respect of not needing power while removing the robot. Again, I see the main concern as safety, and I think that will be the deciding factor.
Unread 12-01-2010, 10:43
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
Re: Grappling hook?
We thought of this exact thing as well last night. Though we may have an idea on how to control it.
John Fogarty
Unread 12-01-2010, 10:46
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Grappling hook?
I saw several bots hang in 04 using hooks but the all had some type of arm extend up with hook on end to catch the bar and the hook and cable were velcroed so they would release from the arm and winch up the bots. Only purpose of the arm was to place the hook.
Unread 12-01-2010, 14:46
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Grappling hook?
Case in point, Team 811:
The black pole on the right telescoped out ~15 feet to put the grappling hook over the 10' chin-up bar, and then a window motor (legal then) pulled Red Streak II into the air v-e-r-y s-l-o-w-l-y .
"It's NOT Just A Robot Thing!"
Unread 14-01-2010, 11:45
Joey P's Avatar
Joey P Joey P is offline
AKA: Prinke
FRC #1676 (Pascack Pi-oneers)
Joey P is a jewel in the roughJoey P is a jewel in the roughJoey P is a jewel in the rough
Send a message via AIM to Joey P
Re: Grappling hook?
Yea I don't think that the Grappling Hook would be such a good idea for this game, but in general it is a good thought. Maybe it can be used in a game in the next few years but I wouldn't for this because it would be dangerous. Plus, what if your hook missed the pole and it latched onto the ball return rack, It could destroy the return rack, which would not be good for your team or the actual competition.
Joe Prinke
_____________________
2011 World Championship, Newton Division, 2nd Seated Team
2011 VA Regional Winner, Industrial Safety Award sponsored by Underwriter Laboratories, & The Entrepreneurship Award
2011 NJ Regional Winner, Co-Winner of the Coopertition Award
2010 VA Regional Winner Undefeated 15-0, Industrial Design Award By General Motors
2010 NJ Regional Winner, Entrepreneurship Award, Ethan Hayon - Dean's List Finalist Award
2009 Palmetto Regional Chairman's Award, Judges Award
2008 NJ Regional Chairman's Award
2008 Chrysler Team Spirit Award, GTR
2007 NJ Regional: 3rd Seated Team, Best Website Award, Johnson & Johnson - Sportsmanship Award, Motorola Quality Award
2007 Buckeye Regional: Motorola Quality Award (again)
2006 Palmetto Regional Finalists (with 16 & 95)
FVC 1676: 2006 Garden State Rumble Champions
2005 NJ Regional Rookie All-Stars
[/color]
Unread 26-01-2010, 16:05
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Grappling hook?
Window motors arn't legal this year?
Unread 26-01-2010, 16:55
Re: Grappling hook?
Sometimes they are, sometimes they aren't. This year, there happen to be 4 in the KOP, 2 LH and 2 RH. That means that those 4 (or exact replacements) are legal, but any others that are on the robot are not.
Unread 26-01-2010, 16:59
Mr_I's Avatar
Re: Grappling hook?
My apologies! I meant to say "van door motor". (Too many details from too many years ...)
Unread 14-01-2010, 11:29
Dick Linn's Avatar
no team (Synergy)
Re: Grappling hook?
Team 975 used a telescoping tube made from nested PCV pipes. There were flat-wound clock springs to extend the arm segments and a small steel cable/winch to control extension and lift, and a hook on the end that was loosely attached. It worked fairly well. In one match at the VCU regional, all four robots were hanging from the bar. That year's robot was unofficially named "hooker".
It's the lowest one in the foreground. (Check out the officials in the background - everyone went wild.)
http://www.chiefdelphi.com/forums/at...d=126348704 6
Name:	4 on bar in 2004.jpg
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 12-01-2010, 10:45
JIMBO4341's Avatar
JIMBO4341 JIMBO4341 is offline
FRC #2151
JIMBO4341 has a spectacular aura aboutJIMBO4341 has a spectacular aura about
Re: Grappling hook?
I don't think this is possible as I think it's likely that you would exceed your vertical allowance. The bars are 84'' high your maximum is 90'' so there's only 6 inches of leeway for your shot to fly over the bar and grapple. Also if you happen to miss you would almost surely exceed your horizontal allowance. They teased us with the grapple bot in the kickoff video .
Unread 12-01-2010, 10:48
AKA: @doctorfogarty
Re: Grappling hook?
make sure the cable atached to your grapple is shorter than what the max is.
John Fogarty
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
How to Hook up LCD magical hands Programming 18 04-03-2007 13:18
HOOK 'EM HORNS!!!! xzvrw2 Chit-Chat 18 06-01-2006 22:40
Hook edomus General Forum 2 23-02-2004 19:00
Batttery hook up piconysm Technical Discussion 3 17-01-2002 18:21
