Go to Post PLIERS: Used to round off bolt heads. - Andy A. [more]
Unread 13-01-2010, 14:14
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Cypress IO board connect
We are currently on the step for programming the IO board, and we are unable to connect to it with our classmate. the little LED comes on, and it makes the "New Hardware" pop sound when we plug it in. However, it does not come up on the PSoC programmer port list. We installed the cypress software on another computer, an it was able to successfully program the board with the FIRST hex file. however, when we plug it into our classmate,the classmate is unable to find it(it says there is no IO board connected on the driver station).
we are considering reinstalling the cypress software, butdoes anyone know why we are having the problem? We have installed the DriverStationUpdate1.
Unread 13-01-2010, 17:30
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Re: Cypress IO board connect
Here at 2199, we are having the same problem.
Unread 13-01-2010, 23:12
Haragorn Haragorn is offline
FRC #0888
Haragorn is an unknown quantity at this point
We fixed this problem by uninstalling all the Cypress programs and then using an external CD Drive to reinstall everything from the disk included in the KOP.
Unread 14-01-2010, 10:30
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
This is still STEVE D, but im using my friend's log on. We were able to reprogram the chip after reinstalling the cypress program, however the driver station is still not able to find an IO board. We reprogrammed it, unplugged the usb, logged off the developer account and logged into the driver station, and then plugged it back in, but it was never found! Again, when we plug the board in the green LED on the board comes on, but in the driver station it says its unable to locate the unit. We have nothing connected to it, are we suppose to connect something to it???
Unread 14-01-2010, 12:01
FRC #0888
We fixed it! we re-reran the DS update, an when it popped up with what to install, we had it remove all cypress componets from the update. then, we ran the update again and had it install the cypress update. We transferred the software to the IO board, and the Driver Station detected the board.
Too all that are having problems with the driver station: Have the update uninstall the componets. then run the update again and install the componets. Its worked for us on all our problems!
Unread 14-01-2010, 13:03
Installing the latest PSoC Update also works.
When you bring up the PSoC Programmer go to the Utilities tab and choose "Check for Update", download and install.
You will need Internet access for this.
Unread 14-01-2010, 20:15
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
where do we find the correct HEX file to load on the card?? or did it come pre-programed??
thanks...
Unread 14-01-2010, 20:31
The hex file is at: All Users/Documents/FRC_IO.v2.hex
Unread 14-01-2010, 22:57
AKA: Tom Lafleur
FRC #0812
thank you very much!
Unread 16-01-2010, 14:26
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
We are hitting the same problem with the Programmer. In this case, would the best course of action be to look up the AVG (antivirus) activation keys, then connect it to the internet and hit "Check for Update?" I don't think we have any external drives, so I hope to fix the problem without buying one or otherwise being slowed down.
Thank you.
EDIT:
I guess we'll try installing it on our programming laptop and see if it still interfaces with the driver station. More information would be helpful, however.
EDIT2:
It's working, but now I'm wondering about the breadboard -- I can only access half the pins.
Unread 16-01-2010, 15:05
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
We need to update the cypress IO board but only one computer in our programing room has internet. Can we download the update on a flash drive and install the update that way?
Unread 16-01-2010, 15:54
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
Im having a similar issue but i have already configured the I/O board but the Driver station doesn't seem to recognize it.
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
Unread 16-01-2010, 16:46
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
you need to uninstall and re-install the driver station update.
Cypress FirstTouch hex file? chronon FRC Control System 6 08-02-2010 12:29
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress Programmable System-On-Chip Solution? 1jbinder Electrical 5 12-01-2010 22:13
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
