Logitech Dual-Action Gamepad - Axis Problem
Hello Everyone,
We are programming using the Logitech Dual-Action Gamepads. We've encountered a problem where we can't seem to get proper values from the X and Y axes on the left analog stick. We've tried printing GetRawAxis for all 6 possible axes, and the left joystick seems to change values on Axes 5 and 6, but gives values of only -1.0, 0 or 1.0 - nothing in between. Has anyone successfully gotten values from this controller on the left analog stick? -Mr. Lim... |
Re: Logitech Dual-Action Gamepad - Axis Problem
Are you using the Gamepad class that I posted last year?
(Going strictly from memory since I haven't played with any code yet this year) As Alan said, there's a "Mode" button on the gamepad that either swaps the left stick and the D-pad or changes the left stick to "digital" mode. Try pressing that button a couple times. |
Are you running the latest DS software? What you are describing sounds like a bug that was fixed during the beta.
On the controller, click the little "mode" button that toggles the little red light on/off.
Thanks guys...
Mode button that toggles the little red light did the trick. Actually, we ended up restarting the DS, which also toggles power to the game-pad, which in turn reset the "D-Pad analog emulation" mode to off. Sounds like just about everyone in this thread was right =P. Thanks again, you can close this thread if you wish! |
| logitech dual-action gamepad | kamocat | NI LabVIEW | 6 | 19-01-2010 20:47 |
| New class for Logitech Dual Action Gamepad | Mike Soukup | C/C++ | 8 | 11-02-2009 20:08 |
| **FIRST EMAIL**/Purchasing 2007 FRC Game Pieces and Yaw Rate Gyro and Dual Axis Accel | GNH2000 | FIRST E-Mail Blast Archive | 7 | 09-01-2007 18:38 |
| Dual-Axis Accelerometer | naor52 | Programming | 18 | 27-01-2006 22:06 |
