Go to Post There's something about building a robot that just makes people enthusiastic about life. - BBnum3 [more]
Unread 15-01-2010, 19:35
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Error: Need to start() me before you can write
When I downloading code in Netbeans, I get the following error:
java.lang.IllegalStateException: Need to start() me before you can write
at com.sun.spot.sdk.tool.frc.AbstractNetConsole.write (AbstractNetConsole.java:188)
at com.sun.spot.sdk.tool.frc.AbstractNetConsole.write ln(AbstractNetConsole.java:213)
at com.sun.spot.sdk.tool.frc.RunTaskNetConsole.syncWi thPrompt(RunTaskNetConsole.java:70)
at com.sun.spot.sdk.tool.frc.RunTask.executeWithNetCo nsole(RunTask.java:118)
at com.sun.spot.sdk.tool.frc.RunTask.execute(RunTask. java:42)
at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:288)
at sun.reflect.GeneratedMethodAccessor90.invoke(Unkno wn Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:35 7)
at org.apache.tools.ant.Target.performTasks(Target.ja va:385)
at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1337)
at org.apache.tools.ant.Project.executeTarget(Project .java:1306)
at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Projec t.java:1189)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:278)
at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:497)
at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:151)
BUILD FAILED (total time: 13 minutes 47 seconds)
Anyone ever seen this?
Thanks.
Unread 18-01-2010, 12:28
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
Re: Error: Need to start() me before you can write
I'm going to bump this because I also get the same error and am unsure why.
Unread 18-01-2010, 22:28
ericarseneau ericarseneau is offline
ericarseneau is an unknown quantity at this point
Which platform is this on?
This looks like a bug in my starting a thread at wrong time.
Does it happen all the time or just sometimes?
Unread 19-01-2010, 18:06
I MAY have found the race condition, hope the problem goes away with this next release.
Before we start - PLEASE read the Manual! dlavery General Forum 43 10-02-2014 21:11
Need help if you can afford it ASAP agriffchs08 Programming 5 17-02-2007 01:44
What do you need to start a team? Jeff Waegelin Starting New Teams 15 07-05-2003 01:18
