Go to Post I am not even out of high school, and my foot is already in the door of my dream job. And FIRST got me there. - half geek [more]
Unread 15-01-2010, 19:41
alex42 alex42 is offline
FRC #1072
alex42 is an unknown quantity at this point
camera delay
We're testing that the camera works using the camera image window on the driver station, and the camera is running smoothly but lagging by 6-8 seconds (so it shows what was happening 8 seconds ago effectively). How can we make it run faster? Also, there is a cyan line running vertically in what appears to be the exact center of the picture, and occasionally flashing.
Unread 15-01-2010, 21:23
Re: camera delay
The cyan line marks the horizontal center, and is drawn on the driver station. To remove it, you can easily delete an icon on the dashboard diagram and rebuild it or run it from source.
The delay is affected by the image size. I suspect that the smallest has the smallest delay, then the medium has a bit more, and the 640x480 would be the largest delay.
The compression factor will have some impact as well, higher compression will transmit less data. As usual, there is a tradeoff. The higher compression will have more artifacts and will not be as accurate at target recognition.
Greg McKaskle
A boolean delay m3rc1l3ss NI LabVIEW 1 18-02-2009 21:51
47 second delay JohnBoucher CD Forum Support 20 07-07-2008 11:11
Delay jasonpeinko Programming 8 18-01-2008 15:56
Delay Help! waiakea2024 Programming 7 21-02-2007 12:41
Delay Gal Longin Programming 1 09-12-2004 10:37
