NetBeans not talking to the cRio
I tried to deploy a program to the cRio by clicking the run button and it always got hug up while it was "Waiting for the OTA server to reply".
Has any one had this problem before? And if so will they tell me how to fix it? |
Re: NetBeans not talking to the cRio
I have the same issue and were getting "No route to host" is that what your getting.
no, after netbeans did some upgrading on the crio it sat there waiting for the "OTA server" for half an hour then i gave up on it.
It sounds like you are running the software from the DVD or a beta version.
You need to update the FRC plugins as described at: http://first.wpi.edu/FRC/frcjava.html You may also need the "mandatory LabVIEW update". |
Ya, I looked into that and made sure that all the updates were installed ,but it was the pre-installed software that the classmate came with, if that matters
If you haven't already, go to Tools>Plugins>Settings Click Add. Use this URL: http://first.wpi.edu/FRC/java/netbea...te/updates.xml and name it anything you want. Now Netbeans should update automatically. |
#7
I am fairly sure i did that already but i make sure and check on monday when i have access to it again.
#8
Also, don't forget to perform the LabVIEW update on whichever machine you are using to format the cRIO, and that the cRIO has the latest v19 firmware.
#10
We are using the classmate to image the crio and it used the v19 update so that shouldn't be a problem
#11
It still wont work and i did every thing
if any one else has something to comment about please reply. |
#12
Hi,
Please post the Run output so we can get to the bottom if this. Thanks. |
| Downloading code: Netbeans does not reset cRIO | ellisk | Java | 8 | 31-01-2010 19:02 |
| Laptop is not finding the cRIO properly? | Studentish | Electrical | 4 | 07-05-2009 12:03 |
| Reimaging the cRio Issues there are no cRio devices on the subnet | Stuart | FRC Control System | 2 | 25-02-2009 23:41 |
| Heres a big problem that I think Discreet does not know what they are talking about. | wes16zeus | 3D Animation and Competition | 9 | 09-01-2002 23:31 |
