Camera not sending image to Classmate?
Right now we have compiled the Circle Tracker Demo to the CRio. We have the crossover cable connected from the camera to port 2 on the CRio, and another crossover cable connected from port 1 on the CRio to the classmate.
There is no image coming up at all either and we are very confused. Any help? |
Re: Camera not sending image to Classmate?
you don't need a crossover to connect the cRIO to the Classmate.
what Language? |
Good luck |
Yea, we just fixed the Dashboard, which wasn't updating. We didn't have a chance to check to see if the camera will send any, but we will tomorrow. I will update tomorrow as well. Oh, and we're coding in Java.
I updated the dashboard, but the camera is still not sending images. However, I am not getting an error message saying Timeout in Communications, so I have no clue what is exactly happening.
You do have the video display on-off switch turned on, right? It's the little control at the bottom of the dashboard video window. It'll show a bright green highlight when you set it to the "on" state.
#7
Yea, we do. We got the dashboard to say "camera running e", but still no camera images. Any ideas?
#8
I don't think I saw mention of configuring the camera. There is a utility to create an FRC user and FRC password on the camera. Without those, the camera will simply return errors, and it may be that the WPI camera libs hide the errors -- not sure.
Connect the camera to the PC, set the PC IP to 192.168.1.1, and run the camera setup utility. Alternately, you can browse to 192.168.1.90 and do the configuration by hand. You can also do this to verify the camera works correctly. Once you log into the camera, you can view images, change settings, etc. Greg McKaskle |
#9
We did configure the camera and tried setting the username and password to FRC, but that still did not fix it.
#10
Run the Driver Station update to uninstall the old Driver Station, then run it again to reinstall it. Just updating it (without the uninstall) sometimes doesn't work.
#11
We did uninstall the old Driver Station. Sorry to be very unhelpful to my situation. Is there anything else I can add that would make this easier?
| Getting Camera Footage on the Classmate | CRASH999 | FRC Control System | 6 | 23-01-2010 12:29 |
| Dashboard not appearing on classmate | railerobotics | Programming | 2 | 20-01-2010 15:42 |
| Java Camera Video on ClassMate | Thomas4019 | Java | 8 | 16-01-2010 00:18 |
| Classmate not loading Dashbaord on bootup | gokul | Control System | 2 | 13-01-2010 10:34 |
| [not-FIRST] Camera Image Processing | Greg Marra | Programming | 11 | 11-03-2008 21:10 |
