Go to Post My wife thought the lead singer, Ozzy Kamen was cute. Darn those rockers. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 17-01-2010, 22:45
caincteam2777 caincteam2777 is offline
FRC #2777
caincteam2777 has a spectacular aura aboutcaincteam2777 has a spectacular aura about
Calculating of traction/friction
is there a formula that can calculate the amount of traction/friction your robot has with a set number of wheels
Unread 17-01-2010, 22:48
mathman05 mathman05 is offline
None #1308
mathman05 is an unknown quantity at this point
Re: Calculating of traction/friction
The number of wheels (the amount of surface area you have on the field) does not effect the amount of friction that you will have. It's a physics thing.
Different types of wheels will have different coefficients of friction on the playing field, though.
Unread 18-01-2010, 00:06
FRC #2777
well the wheels have 1.3 coefficient of friction
Unread 18-01-2010, 00:20
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Force of Friction = Coefficient of Friction * Normal Force
Normal force = Mass * Acceleration due to gravity
If all of your wheels touching the ground have the same coefficient of friction the calculation can be performed once using the entire mass of your robot to find the normal force.
If some of your wheels have a different coefficient of friction the calculation becomes more difficult as the location of your center of gravity will determine how much normal force is applied by each wheel.
Unread 18-01-2010, 00:29
FRC #2777
each has 1.3
formula?
Unread 18-01-2010, 00:33
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
I just posted it.
Find the normal force by taking the mass of your robot and multiplying by the acceleration due to gravity (F=mA). Then multiply this number by the coefficient of friction to find the force of friction.
You should be able to find the conversion between lbs (weight) and (kg) for Earth and the acceleration due to gravity on Earth in m/s fairly easily. Those are the only things you need to perform the calculation.
Unread 18-01-2010, 00:37
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
The formula for force of friction is sum(mu*F_n), where mu is the coefficient of friction for each wheel (i hear 1.3 for the FIRST sticky wheels) and F_n is the normal force (weight) on each wheel. Surface area (i.e. number of wheels) does not come into play. If all your wheels are identical, mu=1.3, and your robot weighs 150 lbs, the force of friction is 195 lbs. This means you can accelerate at up to 195 pounds force / 150 pounds mass = 41 ft/sec^2 before your wheels start to slip.
Unread 20-01-2010, 18:59
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
The coeficient of friction for the KOP wheels are located in section 10 of the game manual. 10.2.4.
10.2.4 The Drive Train
Wheels - The wheels supplied in the 2010 KOP are a combination of slick and sticky treads. The slick
tread material is Celcon M90, and has the following coefficients of friction on white, rippled fiberglass
plastic sheet
Inline, static: 0.06
Inline, dynamic: 0.05
Transverse, static: 0.14
Transverse, dynamic: 0.10
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 20-01-2010, 20:35
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
The numbers in the manual are bogus since we are playing on carpet instead of
white, rippled fiberglass plastic sheet
Additionally, we have two different wheels in the kit and that is only a spec for one... which coincidentally is the exact data from last year.
From the AndyMark site I find that the sticky wheels are listed at 1.0 and the slick wheels at 0.2.
I'd go with those numbers. Expect this to be covered in a future update.
Mark
Brick walls are for other people. - Randy Pausch
Unread 21-01-2010, 21:33
jmanela's Avatar
AKA: Joshua Manela
thanks, i didn't see that.
Calculating relays. VEN Electrical 3 24-04-2007 22:23
calculating distance sur2124 Programming 10 15-03-2006 18:36
Calculating Wheel Size phrontist Technical Discussion 15 07-09-2004 18:55
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
