New router setup not working
Our router from last year isn't working so we bought a new one for this year. We bought a wrt160n. When we put the cd and set it up it's asking us too hook it up to an internet but it is still not connecting. Do we have to set it up this way or is there another way. How do we change our ip for it and what else do we need to change?
Thank you |
Re: New router setup not working
I would reset the router to default.
Plug in your computer and let it get an ip go into command prompt and type in ipconfig look at the gateway field, it should be something lie 192.168.*.* type in whatever your number is into firefox or IE and you will get to the router page you will need the default password, it should be in the manual This will allow you to make whatever changed you need to make. |
You have to remember that last season you had to take your receiver to be encrypted. Unless you have the sheet that they gave you do decrypt the receiver then you would be easy off just doing a master reset on the unit. To the best of my knowledge all linksys devices do a master reset after 30 seconds of holding the reset button while powered on.
Hope it works for you. |
| Laptop not finding router | popo308 | FRC Control System | 7 | 16-01-2009 14:09 |
| Can not connect bridge and router wirelessly | team877 | Programming | 4 | 08-01-2009 00:18 |
| New Vex Ultrasonic Sonars not working | NumBeast | Electrical | 2 | 10-02-2008 00:45 |
| New Vex Ultrasonic Sonars not working | NumBeast | Programming | 0 | 09-02-2008 17:31 |
| New Vew Ultrasonic Sonars not working | NumBeast | Technical Discussion | 0 | 09-02-2008 15:57 |
