Please help with NetBeans
Hello,
I've followed some of the discussion threads involving transferring a default program from NetBeans to the cRIO but I still cannot get it to work for me. The updates are installed, the correct link for future plugin updates is there, and the cRIO is operating with v19. Here is what the code looks like: init: init: No to.jar.file specified. Using "suite\BuiltInDefaultCode_1.0.0.jar" Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\build Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Deleting directory C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\j2meclasses clean: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\build Compiling 1 source file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\build compile: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\j2meclasses preverify: Created dir: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Building jar: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite\Built InDefaultCode_1.0.0.jar jar-app: Using "suite\BuiltInDefaultCode_1.0.0.jar" CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods [translating suite image [closed: false, parent: squawk] ...] ### Excluding compile: com.sun.squawk.Method::getParameterTypes ### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt Romizer processed 73 classes and generated these files: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.sym C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite .metadata C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite .api Expanding: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite\Built InDefaultCode_1.0.0.jar into C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Moving 1 file to C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\suite Deleting: C:\Documents and Settings\Developer\My Documents\NetBeansProjects\DefaultCode\image.suite .api Connecting FTP @10.29.72.2 upgrade: Sending local file image.suite flashapp: deploy: init: Setting up for RUN [cRIO] Waiting for prompt "-> " [cRIO] -> [cRIO] -> xdelete "/ni-rt/system/SQUAWK_DEBUG_ENABLED" Waiting for prompt "-> " [cRIO] deleting file /ni-rt/system/SQUAWK_DEBUG_ENABLED Waiting for prompt "-> " [cRIO] /ni-rt/system/SQUAWK_DEBUG_ENABLED: S_relFsLib_FILE_NOT_FOUND Waiting for prompt "-> " [cRIO] value = -1 = 0xffffffff [cRIO] -> Waiting for cRIO to reboot (1s) Waiting for cRIO to reboot (2s) Waiting for cRIO to reboot (3s) Waiting for cRIO to reboot (4s) Waiting for cRIO to reboot (5s) Waiting for cRIO to reboot (6s) Waiting for cRIO to reboot (7s) Waiting for cRIO to reboot (8s) [cRIO] -> [cRIO] -> * Loading StartupDlls: debug [cRIO] Entering debug.o StartupLibraryInit [cRIO] Debugging is up, target server mounted at /tsfs [cRIO] [cRIO] [cRIO] VxWorks [cRIO] [cRIO] Copyright 1984-2006 Wind River Systems, Inc. [cRIO] [cRIO] CPU: MPC5200 -- Wind River Lite5200 BSP. [cRIO] Runtime Name: VxWorks [cRIO] Runtime Version: 6.3 [cRIO] BSP version: 2.0/10 [cRIO] Created: Jul 29 2009, 13:41:47 [cRIO] ED&R Policy Mode: Deployed [cRIO] WDB Comm Type: WDB_COMM_END [cRIO] WDB: Ready. [cRIO] [cRIO] Leaving debug.o StartupLibraryInit [cRIO] * Loading StartupDlls: NiRioRpc [cRIO] * Loading StartupDlls: niorbs [cRIO] * Loading StartupDlls: NiViSrvr [cRIO] * Loading StartupDlls: nivissvc [cRIO] task 0xee3cf8 (PAL00fb5098) deleted: errno=0 (0) status=0 (0) [cRIO] NI-RIO Server 3.2 started successfully. [cRIO] task 0xc5f148 (NiRioRpc) deleted: errno=0 (0) status=0 (0) [cRIO] * Loading StartupDlls: nivision [cRIO] * Loading StartupDlls: niserial [cRIO] * Loading StartupDlls: FRC_FPGA [cRIO] * Loading StartupDlls: FRC_NetworkCommunication [cRIO] FRC_NetworkCommunication was compiled from SVN revision 2064 [cRIO] FPGA Hardware GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E [cRIO] FPGA Software GUID: 0xAD9A5591CC64E4DF756D77D1B57A549E [cRIO] FPGA Hardware Version: 2010 [cRIO] FPGA Software Version: 2010 [cRIO] FPGA Hardware Revision: 1.3.0 [cRIO] FPGA Software Revision: 1.3.0 [cRIO] * Loading StartupDlls: FRC_JavaVM [cRIO] [cRIO] [cRIO] [OTA Server] Version: 2010 FRC, Dec 30 2009, 15:22:08 [cRIO] [cRIO] [OTA Server] Starting... [cRIO] [cRIO] [OTA Command Server] In serverSocketListener() [cRIO] [cRIO] [OTA Redirector] In serverSocketListener() [cRIO] [cRIO] task 0x2152250 (t2) deleted: errno=0 (0) status=0 (0) [cRIO] [cRIO] Welcome to LabVIEW Real-Time 8.6.1f2 [cRIO] [cRIO] NI-VISA Server 4.5 started successfully. [cRIO] task 0xe62320 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1) [cRIO] [OTA Server] Restarting Java VM [cRIO] [cRIO] [Squawk VM] Starting up... [cRIO] [cRIO] [cRIO] [Squawk VM] Version: 2010 FRC, Jan 11 2010, 23:01:10 [cRIO] [cRIO] [Squawk VM] File SQUAWK_DEBUG_ENABLED not found, starting squawk in normal mode... [cRIO] [Squawk VM] arg: squawk.out [cRIO] [Squawk VM] Squawk command line file SQUAWK_CMD_LINE not found, using default args... [cRIO] [Squawk VM] arg: -suite:robot [cRIO] [Squawk VM] arg: -Xmxnvm:1M [cRIO] Bootstrap suite loaded [cRIO] In Startup [cRIO] Looking for implementation class com.sun.squawk.platform.posix.vxworks.natives.Sele ctImpl [cRIO] Looking for implementation class com.sun.squawk.platform.posix.vxworks.natives.LibC Impl [cRIO] FPGA Hardware GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] FPGA Software GUID: 0xad9a5591cc64e4df756d77d1b57a549e [cRIO] IterativeRobot Constructor Start [cRIO] IterativeRobot Constructor Finish [cRIO] BuiltinDefaultCode Constructor Started [cRIO] [cRIO] BuiltinDefaultCode Constructor Completed [cRIO] [cRIO] IterativeRobot startCompetition() Start [cRIO] RobotInit() completed. [cRIO] [cRIO] Disabled_Init() completed Can anyone make sense of this for me, please? I appreciate any and all help you can provide. Thank you. |
Re: Please help with NetBeans
What's not working?
Ecerything you see there indicated a proper execution. Now, I can guess that you put code into your robot that you expected it to do something. Try a System.out.println("Hello I am here"); in one of the methods and see if it comes out. |
Are you sure you put the code in the right place? Or, if it is code for teleop, are you sure you're in teleop mode (via the FRC Dashboard/Driver Station software) before testing it?
| Netbeans/Overall Java/Code help!!! | a kenny03 | Java | 5 | 18-01-2010 22:32 |
| Netbeans help please | darkorbit | Java | 1 | 18-01-2010 21:36 |
| Help with NetBeans | frcchile | Java | 4 | 13-01-2010 21:51 |
| Help with animation please | Waldo1641 | 3D Animation and Competition | 7 | 05-02-2005 15:52 |
| hey need some help with writing a code please help me here | magical hands | Programming | 9 | 01-01-2004 21:46 |
