Go to Post Every event that starts with "a little bit of fun" has the potential to end in disaster. Please think about all possible outcomes before you do anything stupid. - sanddrag [more]
Unread 19-01-2010, 10:47
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Programming Mecanums in Labview
This is our first year using Mecanum drive and we are having some trouble with programming these wheels in Labview. I realize there are a couple of threads discussing this topic, but I have some specifics I would like addressed. For instance:
1. Do you need one joystick or two to control the drive?
2. Can the holonomic vi be used for this drive system?
3. Are there any tutorials available that address this topic?
4. Any suggestions or tips?
Any information you could supply me with would be very helpful and appreciated. Thanks!
Unread 19-01-2010, 13:19
Re: Programming Mecanums in Labview
1. You need three inputs to control forward/backward motion, left/right motion, and cw/ccw rotation. You can do that with as many or as few joysticks as you want, depending on the features the joysticks provide. We have typically used two joysticks configured exactly as we would for tank drive, along with the average of the X axes for sideways control.
2. The holonomic vi was written specifically for mecanum drivebases.
3. I don't know of tutorials, but there are a number of threads here on the Chief Delphi Forums that talk about how to do it. Try searching; if you still have specific questions, ask.
4. Listen to your drivers and try to make them happy.
Unread 21-01-2010, 08:56
Hadi379's Avatar
FRC #0379
Alan,
Well, as of right now, we are able to drive forward/backward, strafe in all directions off of joystick 1, BUT we have no CW/CCW rotation. I was attempting to get the rotation from joystick 2. I'd like to paste the code here if you would be willing to take a look at it, I feel like I'm making a simple wiring mistake.
Also, when we run the motors, the transmissions make a sound like their fighting themselves, kind of like a jittering motion. Is there anything I can do to refine the program?
Thanks for you time.
Unread 21-01-2010, 10:51
Well, as of right now, we are able to drive forward/backward, strafe in all directions off of joystick 1, BUT we have no CW/CCW rotation...Also, when we run the motors, the transmissions make a sound like their fighting themselves, kind of like a jittering motion. Is there anything I can do to refine the program?
Before investigating software, this could be a simple mechanical issue. If you can't make your robot turn under its own power, you might have your wheels swapped.
Can you easily spin the robot by hand when its motors aren't running? If so, you definitely have your wheels swapped.
Unread 21-01-2010, 13:09
Hadi379's Avatar
FRC #0379
im pretty sure the wheels are arranged properly, plus, if they weren't, would I still be able to drive in the directions we've already achieved? We just can't get the robot to rotate cw/ccw.
Unread 21-01-2010, 14:57
Chris is me's Avatar
AKA: Pinecone
Yeah, if your wheels are the wrong way, then you could still strafe and everything, just not spin.
Unread 21-01-2010, 19:45
Hadi379's Avatar
FRC #0379
Well, I'll have to double check them this weekend, but we arranged the wheels exactly how AndyMark recommends in their drawing...I'll let you know, but I really think it could be a programming problem...I'll post code later tonight if anyones willing to glance at it.
Labview servo programming Delvadar NI LabVIEW 9 01-02-2010 20:29
Programming Toggle Switches in Labview seanl Programming 1 16-02-2009 13:02
FRC LabVIEW programming dlesley National Instruments LabVIEW and Data Acquisition 2 15-12-2008 13:21
Basic Labview Programming Questions comphappy NI LabVIEW 20 13-10-2008 18:29
Labview Programming question pollyproof12 General Forum 2 30-09-2008 16:29
