dualie vs. single omni wheels
It looks like this year will be our first using omni wheels.
Does anyone have experience with dualie vs. single omni wheels? Does one have an advantage over the other in terms of lateral motion? Thanks. -Mr. Van Coach, Robodox |
Re: dualie vs. single omni wheels
The only difference between dualie and single omni wheels is the smoothness in straight direction travel. The gap between the rollers on a single causes a "bumpy ride" The dualie smooths this. As for changes in the transverse motion there should not be a noticeable difference although you do have the chance that you will be in between rollers when turning causing edge wear on your rollers but does not effect performance. .
On an offseason practice bot we noticed when using single omnis that they caused some significant vibration. As we were wheeling it around the shop on the tile floor it was vibrating bolts loose that hadn't yet been tightened down. If we end up using omnis on a competition bot I'm fairly certain we'll go with the dualies just to reduce all that vibration induced stress on the bot.
| AndyMark 4" Dualie Omni Cart video with Kenny Beckwith | Andy Baker | General Forum | 8 | 28-06-2009 10:23 |
| Omni wheels | kajeevan | General Forum | 6 | 15-08-2008 11:47 |
| caster wheels vs. omni wheels | gondorf | Kit & Additional Hardware | 4 | 23-01-2008 22:45 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| Omni Wheels??? | Alex Cormier | General Forum | 1 | 24-01-2004 18:00 |
