Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
Unread 19-01-2010, 20:08
z2daj z2daj is offline
FRC #2836 (Team Beta)
z2daj is an unknown quantity at this point
Send a message via AIM to z2daj
Yet Another Axis Camera Live Feed Issue
Okay, so the programmers here have updated everything humanly possible, and yet the Dashboard - Axis Camera combo refuses to show any type of live feed communication. To make matters a little more perplexing, WindRiver refuses to build the FRC Camera to Dashboard Example code, claiming that "AxisCamera.h", "BaeUtilities.h", and "FRCError.h" exist yet they are clearly visible in the C:\WindRiver\vxworks.6.3xx\target\h\WPILib\Vision directory... I've tried copying the correct files out of the sub-directory but the cRIO refuses to cooperate. Any ideas?
The build errors:
Build Started in Project 'CameraToDashboardExample':   2010-01-19 20:08:15
Generation of makefiles started.
Generation of makefiles finished (Elapsed Time: 00:00).
Platform: Wind River VxWorks 6.3
Command: make --no-print-directory BUILD_SPEC=PPC603gnu DEBUG_MODE=1 TRACE=1
Working Directory: C:/windriver/workspace/CameraToDashboardExample/PPC603gnu
if [ ! -d "`dirname "CameraToDashboardExample/Debug/Objects/CameraToDashboardExample/CameraToDashboardExample.o"`" ]; then mkdir -p "`dirname "CameraToDashboardExample/Debug/Objects/CameraToDashboardExample/CameraToDashboardExample.o"`"; fi;echo "building CameraToDashboardExample/Debug/Objects/CameraToDashboardExample/CameraToDashboardExample.o"; ccppc -g -mcpu=603 -mstrict-align -mno-implicit-fp -mlongcall -ansi -Wall  -MD -MP  -IC:/WindRiver/vxworks-6.3/target/h/WPILib -IC:/WindRiver/vxworks-6.3/target/h -IC:/WindRiver/vxworks-6.3/target/h/wrn/coreip   -DCPU=PPC603 -DTOOL_FAMILY=gnu -DTOOL=gnu -D_WRS_KERNEL    -o "CameraToDashboardExample/Debug/Objects/CameraToDashboardExample/CameraToDashboardExample.o" -c "C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp"
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:24:25: AxisCamera.h: No such file or directory
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:25:26: BaeUtilities.h: No such file or directory
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:26:22: FrcError.h: No such file or directory
In file included from C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:27:
C:/WindRiver/vxworks-6.3/target/h/WPILib/PCVideoServer.h:28: error: expected class-name before '{' token
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp: In member function `virtual void CameraToDashboardExample::RobotMain()':
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:39: error: `DEBUG_SCREEN_ONLY' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:39: error: (Each undeclared identifier is reported only once for each function it appears in.)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:39: error: `SetDebugFlag' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:42: error: `k320x240' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:42: error: `ROT_0' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:42: error: `StartCameraTask' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:43: error: `LOG_ERROR' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:44: error: `GetLastVisionError' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:44: error: `GetVisionErrorText' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:44: error: `dprintf' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:46: error: `LOG_DEBUG' undeclared (first use this function)
C:/windriver/workspace/CameraToDashboardExample/CameraToDashboardExample.cpp:47: error: `Wait' undeclared (first use this function)
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [CameraToDashboardExample/Debug/Objects/CameraToDashboardExample/CameraToDashboardExample.o] Error 1
Build Failed in Project 'CameraToDashboardExample' (Process Exit Value was 2):   2010-01-19 20:08:17   (Elapsed Time: 00:02)
There is nothing to fear, but fear itself
Unread 20-01-2010, 10:18
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: Yet Another Axis Camera Live Feed Issue
We have had the same error with this example, but haven't gotten it fixed yet. You might want to try the "FRC 2010 Vision Demonstration Program" example. It should build correctly if you have the Workbench Update installed. Also, check out this thread http://www.chiefdelphi.com/forums/sh...threadid=80536 post #6. It might be the solution to your problem.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 24-01-2010, 13:47
Thank you for your help, that link did the trick
Live Feed with Axis Camera CHSboy Programming 6 24-03-2009 14:43
2009 - Live camera feed to drivers during a match? Travis Hoffman Rules/Strategy 23 21-01-2009 17:43
Getting Live Feed from Axis Camera in Windriver Inoperational C/C++ 8 15-01-2009 01:21
Getting Live Axis cam feed popo308 Programming 7 09-01-2009 19:14
Anyone know how to get a live video feed from your axis cam? Jazonk FRC Control System 7 03-01-2009 20:08
