Go to Post My hammer is my therapist, my weapon against bent metal, unwilling bolts, and tall nails. - Morgan Gillespie [more]
Unread 20-01-2010, 01:41
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
"Toughbox Nil" - Integrated Chassis/Gearbox
Inspired by the new Toughbox Nano and taking some additional cues from a few of the "West Coast" drives, I've been doing some CAD experimenting and came up with this:
It utilizes a chassis of 3" x 1.5" x .125" aluminum square tubing, the same stuff that the Toughbox Nano is made from. It requires the same thru-holes in the side rail, plus an access pocket through the top.
No idea if we'll pursue anything like this or not, but I though it was interesting to draw and discuss. Has anything like this been done before? Any comments?
Unread 20-01-2010, 01:47
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: "Toughbox Nil" - Integrated Chassis/Gearbox
Wow,
Great job, its great to see more CAD on CD. Btw any ideas on how easy it will be to maintenance?
This has been done to an extent, teams tend to integrate their gearboxes into their side rails. Such as Pink in 2006.
But the design looks awesome and very unique, hope you guys pursue the idea.
-RC
R.C.
MadTown Robotics Team 1323
Unread 20-01-2010, 02:07
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Looks excellent.
The only advice that I can give is that make double sure you cut in very functional access holes so you can do simple maintenance and assemble easily.
Unread 20-01-2010, 03:46
craigboez's Avatar
Mechanical Engineer
I don't imagine it'd be any harder to maintenance than say, a Toughbox Nano? After install and greasing it'd just get periodic checks to make sure everything was still functioning properly. For a sealed gearbox a plate could be made to go over top of everything that would keep loose parts from falling in, or alternatively the access pocket could be on the bottom side instead of the top.
Something about this still doesn't have me convinced that it's a good idea. The modular design of motor -> gearbox -> chassis ensures that if any one component fails it can be replaced and not bring the whole robot to its knees. I think if well designed it should work just fine, but when something unexpected happens it's nice to know that a spare Toughbox is only 15 minutes from being installed and running.
Unread 20-01-2010, 07:44
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Neat Idea,
We did that exact thing last year and experienced no failures. Its perhaps a little tougher to assemble than a standard gearbox, however we felt it made up for that slight difficulty in great packaging.
My one caution would be to watch which way your bearing flanges face, you want to design it in such a way that a bearing can't fall out and cause a failure.
For Reference here's a picture of ours.
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
Unread 20-01-2010, 13:32
craigboez's Avatar
Mechanical Engineer
Originally Posted by Chris View Post
Neat Idea,
Cool. I figured somebody had to have done this already. It's great to know that it has been used without issues, even if 2009 wasn't exactly a year hard on drivetrains. Will you guys be implementing something similar this year?
Goig "wide" with the chassis Joe Finkel Technical Discussion 30 13-01-2009 16:43
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
Where Are "Chassis & Drive Train Instructions" Robeaux Technical Discussion 1 10-01-2006 16:17
Dewalt/FP gearbox "sticking" in reverse brandon.heller Motors 5 24-02-2005 14:11
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
