Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 20-01-2010, 15:24
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
paper: CG Migration of Robot Crossing Bump using Powerpoint
Thread created automatically to discuss a document in CD-Media.
CG Migration of Robot Crossing Bump using Powerpoint by IKE
We used this technique during our chassis design process to look at some important aspects towards going over the bumps. Seeing a lot of neat Chassis up on CD, I felt this would be a useful visualization tool for other teams.
Unread 20-01-2010, 15:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: paper: CG Migration of Robot Crossing Bump using Powerpoint
This is an awesome resource to show younger members (and some veterans) the effect of COG on bump crossing.
I also love the humor, one of the Engineers at my job and I got quite a laugh out of the robot face plant.
Thank you.
-Dustin Benedict
Unread 20-01-2010, 15:42
Diminish's Avatar
Diminish Diminish is offline
Rage
FRC #3006 (Red Rock Robotics)
Diminish is an unknown quantity at this point
Really sweet powerpoint!
Also, did you consider that the wheel base for most robots will not be so continuous? As in, there will probably be a gap in the middle (4 wheeled bot) and it would force the "crest" moment to be a lot sooner, possibly enough to get away with a high CG robot...
But I assume this was mainly for your team, and your team has chosen treads, so thanks for sharing with us!
Unread 20-01-2010, 15:45
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Yes, this is essentially a treaded design. I have used this technique to look at several designs (4WD, 6x6 flat, Rocker....) I chose to present the tank as it has the most impressive Transistions.
Unread 20-01-2010, 15:48
Diminish's Avatar
Rage
Wink Re: paper: CG Migration of Robot Crossing Bump using Powerpoint
"I chose to present the tank as it has the most impressive Transistions"
Theatricality - I like it
Unread 20-01-2010, 17:39
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
For those that are wonder where their CG will end up, take a look at http://www.chiefdelphi.com/media/papers/2048
It allows both weight budgeting and CG estimation. You can use this to get an estimate before the CAD modeling gets too far along. 10-20 minutes spent now on budgeting can save hours (or even days) of rework.
I apologize that the user interface is not slicker and am open to suggestions for improvement.
Mark
Brick walls are for other people. - Randy Pausch
Unread 25-01-2010, 15:42
BC_caveman BC_caveman is offline
AKA: Brian
FRC #1885
BC_caveman has a spectacular aura aboutBC_caveman has a spectacular aura aboutBC_caveman has a spectacular aura about
Thumbs up Re: paper: CG Migration of Robot Crossing Bump using Powerpoint
Excellent graphical presentation. I would like to suggest a more correct terminology usage. The center of gravity does not change (unless you have moving components), the Moment of gravity is what is being depicted by the vector. This, along with center of mass, is used in aircraft and ship stability calculations also.
Unread 30-01-2010, 22:55
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Pretty cool paper. It is a great visual way to demonstrate CG. I like it.
-John
White Paper Discuss: Cost Effective Robotics: Using Vex in FRC artdutra04 Extra Discussion 2 09-01-2006 01:47
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
White Paper Discuss: Using an Operator Interface with the 2004 EDU RC CD47-Bot Extra Discussion 6 20-01-2004 21:11
