Go to Post Know what really grinds my gears? Metal Shavings. - Briansmithtown [more]
Unread 21-01-2010, 11:13
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
Sensitivity of Cypress board
I recently wired a cypress board to a single switch. I have good communications and everything, however the board seems to be really sensitive. If i am holding the board, all of the inputs will constantly flash on-off. On the switch that i wired, when i switch off, the light stays off on the digital display. but when i turn it on, it will constantly flash. Is this normal. I assume its just due to my poor wiring job. Anything to reduce this sensitivity, other than rewiring with solid core wires?
Unread 21-01-2010, 11:22
Re: Sensitivity of Cypress board
If you are using the extended mode, you may need to enable a pull up or pull down on the digital inputs. Each digital input can be configured to default to high, default to low, or default to nothing (aka flashy/jittery).
PS: I think this set-able pull up/down is the coolest thing since capacitive touch sensors and sliced bread.
Cypress Board Issues kgzak FRC Control System 4 02-02-2010 18:40
Cypress board LAYOUT SteveD FRC Control System 11 23-01-2010 11:23
Cypress board bls0620 Electrical 4 17-01-2010 23:22
Cypress Board Configuration Geek 2.0 FRC Control System 12 17-01-2010 04:23
Cypress IO board connect SteveD FRC Control System 12 16-01-2010 16:46
