Go to Post Will we finally get to play music on our robots for once!? - Hitchhiker 42 [more]
Unread 21-01-2010, 16:17
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Cylinder damage with high kinetic energy?
Is this a concern for 2010 kickers?
I talked with Bimba to see what they thought. A gal in support said that the cylinders should be limited to 20 ips independent of bore size used. She said that the cylinders on the First list had no internal rubber stops to absorb energy. I asked if the load mass mattered... surely a 20lb mass would be more damaging than a 1 lb mass if traveling at 20 ips. This didn't seem to concern her so long as the 20ips was held.
So I'm thinking most of us are exceeding these limits and therefore should include external stops to preclude piston hammering.
I'd like to hear peoples opinions on this.
Unread 21-01-2010, 16:31
Racer26 Racer26 is offline
Re: Cylinder damage with high kinetic energy?
I highly doubt many of us are exceeding 20 inches per second
Unread 22-01-2010, 12:48
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
[Paraphrased] A gal in [Bimba] support said that the cylinders should be limited to 20 ips independent of bore size used, and FIRST cylinders have no internal rubber stops to absorb energy....] So I'm thinking most of us are exceeding these limits and therefore should include external stops to preclude piston hammering. I'd like to hear peoples opinions on this.
A) 20ips is actually quite fast.
B) Yes, your mechanism should NOT allow the cylinder piston itself to be the stop. That can break the cylinder. Add an external stop, JUST before the stroke causes the piston disc to hit its end plate.
C) IMO, another solution is to just to
- use the cylinder to "[MaleChicken] a spring" to a catch (the CDF editor won't let me use the "Naughty Word" term! <lol>).
- disengage / back the cylinder off to its Rest Position.
- NOW release the spring with a second tiny cylinder (or other device), by pulling a pin.
A bit more fab and a control ritual, but it saves a LOT of wear and tear on your cylinder because it is not DIRECTLY involved in the firing of the device itself anymore.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 22-01-2010, 20:15
DonRotolo's Avatar
Back to humble
FRC #0832
How, exactly, does one Rooster a spring?
pic: Aiming High with Balloons! Pat Arnold Extra Discussion 7 19-06-2006 08:21
Question about rules: Does ball damage count as field damage? Jevin H Rules/Strategy 11 17-01-2006 14:21
Wheeler High Breaks Bread With Wheeler High dangerousdave Championship Event 0 20-04-2005 23:28
Team 781: The Kinetic Knights- Website and Forums GAT-X105 STRIKE Website Design/Showcase 0 31-03-2005 14:26
Team 781, Kinetic Knights MaxTheFlame312 Chit-Chat 2 30-04-2002 15:55
