Go to Post No Firsting way! - Tytus Gerrish [more]
Unread 21-01-2010, 18:59
ProgrammerJoe ProgrammerJoe is offline
FRC #2832
ProgrammerJoe is an unknown quantity at this point
"Unable to open resource files."
After getting the classmate PC out of the KOP, I immediately tried to boot up Labview, and got a little vbs prompt that said, "Unable to open resource files," and Labview refuses to open. This chain of events persisted on launch, even after the mandatory update, and is a bit annoying as it takes a potential programming computer out of the mix.
Has anyone else had this error, and/or got any ideas on how to repair it?
Unread 21-01-2010, 19:56
elmer_fud elmer_fud is offline
mentor/code monkey
FRC #2859
elmer_fud is an unknown quantity at this point
Re: "Unable to open resource files."
hmmm, I am not sure if this will do anything but have you tried installing the labview update on the classmate? We have done all our programming on another computer because I think it will be difficult to program on a small screen
Unread 21-01-2010, 20:01
FRC #2832
We tried the update, and we got nowhere. We could technically run with no Labview on the classmate as we do have a dedicated Programming machine that works fine, but it would be nice to have another machine in the mix, as we are a bit strapped for cash this year and could use all the physical machines we could get.
Unread 21-01-2010, 20:24
Don't ask me how your laptop was special, but that indicates a corrupted install. To be certain, please post the exact message. It may be possible to hand patch a file or two, or it may be best to restore from the USB key in the kit.
Greg McKaskle
Unread 22-01-2010, 00:10
FRC #2832
That's what it said post update, "Unable to open resource files." Pre update, it said there was a file either interfering with or a corrupted kernel32, and if I am just going to flash the drive anyway, I might as well try a DIY patch.
Now will I have to reinstall Labview after the patch, or is it all inclusive?
Unread 22-01-2010, 00:15
I believe that the LV image is on the restore image, but I don't actually have one, so you should get verification from someone who has used one.
I think the easiest thing to do is contact technical support at NI and ask them to send you the resource directory zipped up. If that doesn't work, it is either time to reinstall LV from the DVDs or to do the USB restore.
Greg McKaskle
"Aim High" Autodesk Files Team 2037 Technical Discussion 6 07-01-2009 14:04
"Open Source" Drive Systems CraigHickman Technical Discussion 21 27-06-2007 17:45
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
"Open-Source" Balancing development Project MattK General Forum 10 08-08-2003 22:27
