Switching to Holonomic Drive
In the teleop. VI we tried to replace the arcade drive with the Holonomic Drive. When we try to build the code it gives us an error that says to fix the Robot Main.vi. We are fairly new to Labview, all of our programmers graduated last year. Any help would be appreciated.
We started with the FRC cRIO Robot Project provided. Thanks |
Re: Switching to Holonomic Drive
In the upper left tool bar there is usually a white Run arrow.
When you have broken code the arrow becomes broken and gray. If you click on it, it will tell you what your errors are and will actually take you to the mistake on the block Diagram. |
| Holonomic Drive Help | star_lancer | NI LabVIEW | 2 | 01-02-2010 22:39 |
| Holonomic drive vi with mecanum wheels | dwodrich | NI LabVIEW | 7 | 18-01-2010 16:01 |
| Holonomic drive and ramp | robotaddict | Technical Discussion | 11 | 13-01-2006 16:57 |
| Holonomic Drive Question | Jeff Waegelin | Technical Discussion | 12 | 20-11-2005 21:23 |
| Holonomic Drive Mathmatics Discussion | robotaddict | Programming | 35 | 15-10-2005 13:29 |
