Fisher Price Gearbox Torque
Does anyone know the torque of the Fisher Price Gearbox?
Re: Fisher Price Gearbox Torque
Stall torque is listed as 0.45 N-m for the motor.
For the gearbox, not the motor itself.
To find the torque output of a gearbox, multiply the stall torque of the motor by the inverse of the reduction in speed the gearbox provides.
For example, if the FP motor stalls at .45 N*m, and the gearbox provides a reduction of 1/5, multiply .45 by 5 to get the gearbox torque. Last edited by BHS_STopping : 22-01-2010 at 19:34. |
A. Last year's gearbox was ~139:1. I haven't taken this years apart to verify yet.
B. This is a great learning opportunity, learning how to do it yourself is going to be the fastest and most reliable route to your answer. Take it apart and count the teeth. Stage Gear Ratio = Driven Gear / Driving Gear Multiply the 4 Stage Gear Ratios of the FP trans to get the overall ratio. The white paper at http://www.chiefdelphi.com/media/papers/2284 should provide some guidance for getting the gearboxes apart and such. C. 0.45 N*m is the torque for stall at 70A, don't plan on having that much torque available for any length of time. You can scale it to the 30A torque by multiplying 0.45 N*m by 30A / 70A. There are numerous white papers on this subject. D. When you get it figured out, post it back here. Last edited by kramarczyk : 22-01-2010 at 20:27. Reason: added some punctuation |
The gearbox ratio is approximately 125:1.
This would put the F-P motor with gearbox at around 41.5 ft/lbs. Unless I'm crazy. . . |
#7
In FRC applications, half of stall torque is usually a good number to design around. You can use the sheet here to figure out how fast the motor spins at that torque. |
#8
How did you come up with this number?
#9
He opened up the gearbox and counted the teeth. My team mentors/shares a shop with his and I saw him hard at work counting teeth.
#10
Awesome! I just came up with a slightly different number, 122:1. Attached is my counting work from this evening for comparison.
#11
I've just used 128:1 in the past to make the math a little easier. I think we arrived at that number many years ago by hooking the motor and gearbox combo up to a charged battery and counting the number of Revs of the output shaft observed in 30 seconds. Then compared that to the specified no-load RPM and rounded off. |
#12
I am curious if we have the same gearbox with the rumbling about different motor pinions that I have heard. At least one team claims to have received two different gearboxes in the same KoP. In past seasons I have heard the FP gearbox provided anywhere from 122:1 to 144:1 so I was trying to take the additional steps to back up the numbers provided by including the spreadsheet. |
| Fisher Price Gearbox? | excel2474 | Technical Discussion | 10 | 12-01-2009 21:14 |
| Fisher Price Torque | Halo4life | Motors | 1 | 25-01-2008 15:35 |
| Fisher Price Gearbox | nreynolds | General Forum | 23 | 22-01-2008 13:18 |
| Fisher-Price Gearbox? | Aaron | Motors | 4 | 17-02-2004 17:41 |
| Fisher Price gearbox | Manoel | Motors | 0 | 14-02-2003 16:06 |
