We made sure the ethernet cable connection is good, power is good, the only light on is the power light on the Crio. The status light turns yellow for the first 5-7 seconds before turning off. The Crio was working yesterday. Help us please!
-3131 |
Re: Crio not communitcating with Classmate!
did you attempt to use the imaging tool and reimage the cRio? and is your IP address set correctly on the DS?
| Camera not sending image to Classmate? | TPNigl | Programming | 14 | 22-01-2010 17:05 |
| Driver's Station not communicating with cRio | Alexandstein | Technical Discussion | 8 | 21-01-2010 21:05 |
| Dashboard not appearing on classmate | railerobotics | Programming | 2 | 20-01-2010 15:42 |
| Laptop/Classmate/cRIO/bridge/router wiring help | ricechrisbtreat | Programming | 2 | 17-01-2010 08:58 |
| CRIO not working with Windriver | dpeterson3 | C/C++ | 7 | 07-01-2009 20:49 |
