Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
Unread 22-01-2010, 21:42
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Axis camera on classmate
I was trying to run the target detection tests on the classmate but for some reason I couldn't connect to the camera
A few days ago we were trying out the camera and tracking system on our development laptop and it worked just fine. However due to some other problems we had to install everything on there, so that left only the classmate with the vision assistant. I'm using the same cable we used to connect to the other laptop and the camera works just fine forwarding images from the cRIO. I did set the 192 ip on the classmate for the camera and did try the camera setup tool, nothing seems to work. On a ping I get a "destination host unreachable" message
Unread 23-01-2010, 05:47
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Axis camera on classmate
Don't forget that the driver station app sets the IP address for you to the appropriate one for being a Driver Station. Make sure your IP address change didn't get changed right back.
Getting Camera Footage on the Classmate CRASH999 FRC Control System 6 23-01-2010 12:29
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
Java Camera Video on ClassMate Thomas4019 Java 8 16-01-2010 00:18
Axis Camera ehochstein Programming 2 21-02-2009 00:16
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
