Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Unread 23-01-2010, 10:01
Johnboi_117 Johnboi_117 is offline
FRC #2474
Johnboi_117 is an unknown quantity at this point
Magnetic Lock
Are magnetic locks legal, or are there rules against using them?
John, 2474
Unread 23-01-2010, 10:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Magnetic Lock
Is that like an electromagnetic solenoid? If so then it the rule book mentions it.
http://www.chiefdelphi.com/forums/sh...ad.php?t=79928
has more info.
Unread 23-01-2010, 10:27
FRC #2474
Re: Magnetic Lock
No, there is no solenoid involed. Its just an electric magnetic lock. Like what they use to lock doors.
John, 2474
Unread 23-01-2010, 10:35
MrForbes's Avatar
AKA: Jim
Re: Magnetic Lock
It is an electromagnet, right?
I didn't see anything in the rules about electromagnets, so perhaps you could ask on the Q&A. Since solenoids are prohibited, and an electromagnet is half a solenoid, it might not be allowed. Apparently they were allowed in 2008.
Unread 23-01-2010, 11:14
FRC #2474
Re: Magnetic Lock
Ok thanks, I'll do some more research.
Unread 23-01-2010, 14:36
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Magnetic Lock
This Q&A may be pertinent:
http://forums.usfirst.org/showthread.php?t=13979
Unread 25-01-2010, 02:45
mikeleslie mikeleslie is offline
FRC #1189
mikeleslie will become famous soon enough
Re: Magnetic Lock
Are these automotive locks or building locks, and just out of curiosity, who uses just magnets. Most of the locks I know of use motors of some type, and some ones from the 40's through 60's use either vacum or hydraulics...but them I'm dating myself.
Unread 25-01-2010, 03:32
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: Magnetic Lock
We used locks like these for years with no break-in problems.
http://www.maglocks.com/magnetic_locking.htm
Key cards instead of keys. Full audit trail of entry and exit. Battery backup for power fail. Security system locks and unlocks on programmed schedule.
Unread 25-01-2010, 08:18
Re: Magnetic Lock
John,
Please ask the question on the Q&A. It will make the job of your inspector a little easier. In the past, if the magnet part attracted(moved) another part, it was considered to be a solenoid and not legal. If you are thinking of using this for a mechanism that would lock you into a hang position then remember that the robot is disabled at the end of the match and power to the device would be removed.
Unread 25-01-2010, 10:23
Re: Magnetic Lock
... if the magnet part attracted(moved) another part, it was considered to be a solenoid and not legal
what if it just held another part in place, once that part had already moved into position via some other force.
Unread 25-01-2010, 10:32
Happy Birthday! EricH EricH is offline
Re: Magnetic Lock
The Q&A has ruled. http://forums.usfirst.org/showthread.php?t=14093
It is legal for that specific use, provided that it doesn't violate other rules.
Magnetic Reed Switches... Transformers Pneumatics 5 17-02-2007 01:12
Magnetic Fields? Robostang 548 Electrical 2 05-02-2007 08:42
Magnetic Sensor on Pistons(help) DPPT1717 Pneumatics 10 12-01-2007 12:00
Magnetic Flux Keith Chester Math and Science 3 11-04-2005 09:35
magnetic sensor Justin_302 Electrical 5 22-02-2005 13:32
