Problems Imaging the cRIO
Hi everybody,
We are unable to image the cRIO. When we try to, it says "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet." We've tried to reformat, but that ran for over half an hour. We can ping the port on the cRio, and the Computer we are downloading from has the IP address of 10.22.34.6 with a subnet mask of 255.0.0.0 We are trying to reimage with v19, and are coding in Java(And checking that box on the Reimage tool.) Thank you in advance! Team 2234 EDIT: We were able to download and reimage with another computer, but we don't get voltage readings on the Driver Station. When we try to run the code, the jaguars continue blinking, as if they have not been initialized. Any ideas? Last edited by rhoads2234 : 23-01-2010 at 14:55. Reason: More information |
Re: Problems Imaging the cRIO
Similar problem.
We are using LabVIEW and tried two computers, both got the same error. We tried puting the cRio in Safe Mode, running the imaging tool and formatting it, turning safe mode off and imaging it, and that worked... better. It failed while uploading the configuration file. We have not yet found a solution |
Hmmmmmm.....an epidemic? Same issue here....had to leave school before the reformatting was done. Will try again tomorrow.
Try reimaging the Crio with the classmate (should have an ip of 10.XX.YY.5) but make sure you have the latest update installed.
Thanks, timytamy |
We tried first on the Classmate after installing the updates and rebooting. Then we tried another laptop.
Generally, my advice is to simplify the network as much as possible. Eliminate switches, other network connections, turn off firewall (completely off), turn off wireless network and any other types of IP. Just for grins, stop apps that don't need to be running.
Greg McKaskle |
#7
No other networking. Direct connection.
After we turned on safe mode and formatted the cRio, it progressed further in the imaging process and then when uploading the configuration files it got an error... forgot the number but it involved timeout on reboot |
#8
Not that there's a real answer in the other thread, just a happy ending, but I think this thread is the same problem as this other thread, isn't it?
http://www.chiefdelphi.com/forums/sh...threadid=80441 |
#9
Problems re-reimaging again and again
We're use Labview. Every time we develop new code and try to deploy it or connect to the cRIO, there a error that says the vi's in the start up application will not open and will remain closed if you continue to apply and deploy. I found out the by using the 'cRIO Imaging Tool' and hitting 'Format controler', the pproblem is removed and we can deploy the code and run a drive test. But when we switch users back into the developer the same problem occurs and the cRIO needs to be re-imaged again. Running the 'cRIO imaging tool' with the format controler takes about seven minutes to finish; and ontop of that we still need to deploy and build the code which take another five to seven minutes. We seem to be spending a lot of time re-reimaging the cRIO to fix our problem. How do we fix it?
#10
Re: Problems re-reimaging again and again
Can you copy and paste the exact error message you're getting? What you're describing sounds very similar to an informational message that isn't an error, but before I give any advice I'd like to see what you see.
#11
#12
When we try to connect/deploy to the cRIO in developer labview we get this message:
'This VI is part of a Real-Time Startup Application. All VIs on the target will be closed if you choose to apply and continue with deployment.' The message also highlight the VIs- Auto. Independent; Robot Main; Send Image to PC; Async VI Agent; Acquire Image; HandleRuntimeErrors. How Do we fix it and stop re-reimaging with the imaging tool with formatting controller everytime? Last edited by BLProgram2010 : 31-01-2010 at 14:14. |
#13
That's just a message you can safely ignore.
We all do. It's just warning you that you're replacing the code that's already on the cRIO, but isn't that what you want to do? |
#14
It was an 'ID 10 T-Error'
Thank you so much ![]() |
#15
PEBKAC
![]() We all have those days... |
| cRIO Imaging Error | Scip | Programming | 1 | 20-01-2010 21:48 |
| cRIO imaging | alex42 | FRC Control System | 3 | 16-01-2010 20:05 |
| cRIO imaging tool | dnrobotics11 | Programming | 4 | 14-01-2010 23:32 |
| Problem with cRIO Imaging Tool | Doc Wu | FRC Control System | 7 | 15-12-2009 19:47 |
| FRC cRIO Imaging Tool | furiousgeorge | Programming | 1 | 06-02-2009 09:52 |
