Go to Post It is possible to live without the Big sponsors, it just takes a lot of fund raising and hard work. - Raumiester2010 [more]
Unread 23-01-2010, 13:37
Kory's Avatar
Kory Kory is offline
Kory
FRC #1569 (Haywire)
Kory is an unknown quantity at this point
Windriver not recognizing user created .cpp
We have extensively edited our .cpp file in a windriver project but none of our commands are taking place. For example we disabled all the motors but they still run when we compile and run the code. We are positive that these actions should take place from the written code. Does anyone know exactly where we need to move our .cpp file so that it will be compiled into our output file?
To everything a season a time, to every purpose under heaven.
Unread 23-01-2010, 13:49
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Windriver not recognizing user created .cpp
Do you know where the file you're editing is?
Is it a file that was already included in some sample project?
Are you editing inside Workbench, using a Workbench editor, or outside?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 23-01-2010, 13:53
Kory's Avatar
Kory
FRC #1569 (Haywire)
We are editing using windriver it is myrobot.cpp from the simple template sample project which is the project we are compiling. It is in the workspace folder in windriver as part of the project
Unread 23-01-2010, 13:56
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Then it would seem most likely that you haven't correctly deployed the new DKM -- that is, it's probably being built okay, it's just not actually running on your bot.
I think you might benefit from watching this online video.
http://users.wpi.edu/~bamiller/Using...Workbench.html
Windriver does not finish building unobtainium-42 C/C++ 8 26-10-2009 13:33
Location of WPI Library cpp files attached to Windriver marccenter C/C++ 5 11-02-2009 12:47
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
Sensor Warning-Lighting is not created equal Adam Y. Technical Discussion 9 09-01-2005 18:30
