Go to Post Holy Orbit ball Batman!!!!!!!!!!:yikes: - yodameister [more]
Unread 23-01-2010, 23:16
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Kicker Space Constraints
3132 from Down Under here,
Just checking into Chief Delphi and I've got some questions for that cranium of yours.
Our dedicated mechanical team has given us a generous 2 inches of room in which we have to slot in our kicker. Since our chassis is so low, the ball is taller than the AndyMark frame itself, so some questions rise for my fellow engineers.
For the kicker, we're using a rotating cam to build up tension and then release it using our 'super secret' method. Now, the current design is direct driven, but we're also considering using a lever instead. I was just wondering what advantages the lever would have over the direct driven kicker.
Also, what would be the most suitable CAD software to model the kicker in. I would preferably want software that supports animation and simulation.
Thanks, 3132.
Unread 23-01-2010, 23:34
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Kicker Space Constraints
Every FRC team has free access to the autodesk products for different awards, prototyping, and much more. You can make a login here:http://students7.autodesk.com/?nd=first_home&lbon=1
You can download the products, but i would recommend inventor for prototyping. It is a very in-depth program, but it is very useful. If you create your whole robot on this program to these specification you can also win an award at one of the competitions, if yours is the best.
http://www.usfirst.org/uploadedFiles...sk%20Award.pdf
Category one is the inventor award. 3d animation uses a program called 3ds max, an animation program. It is similar to the programs used by pixar. That is the animation award, also on that .pdf.
If you have any questions please pm me.
Unread 24-01-2010, 10:18
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
The bumpers are required to be attached to your frame at a hieght of 10 to 16 inches. If your frame is lower than the ball, how are you going to meet the rule for bumpers?
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 24-01-2010, 11:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Have an upper and lower section of the frame? Our frame starts at 4" off the ground and has a second level at 13" for bumper attachment.
[OCCRA]: Rule #RB6 - Physical Constraints SWIM OCCRA Q&A 1 12-09-2008 21:17
How do motion constraints work? Gherkinman Inventor 7 22-02-2007 20:18
constraints in assemblies Adama Inventor 7 04-12-2006 16:20
Inventor popping sound for constraints is gone sanddrag Inventor 10 16-01-2006 14:55
Driving constraints in assembly Jan Olligs Inventor 0 25-02-2002 07:11
