Go to Post Dave Lavery just responded to one of my posts. I think that I might die. - Karibou [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 25-01-2010, 22:10
Left and Right configurations with Sheet Metal
We have a lot of sheet metal parts on our robot that we design using Solidworks. Inevitably, there is a left and right version for most of them, where the only difference is that most/all of the bends are bent the other way. To do this, we normally have to remodel a significant amount of the part, and add to the clutter of the model.
With Configurations, we can easily make bigger and smaller versions of the same part, or ones with extra or fewer features. But what we haven't found out how to do is just flip all the bends to the other side, or take the current bends and instead bend them the other way without remodeling anything. Is there a good way to do this?
Thanks,
Austin Schuh
Unread 25-01-2010, 22:19
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: Left and Right configurations with Sheet Metal
Thanks,
Austin Schuh
You might have luck with dropping the part into an assembly and selecting INSERT>MIRROR COMPONENTS. You'll need to define a plane about which the part is mirrored and the software will recreate it based on that information.
--Madison--
...down at the Ozdust!
Unread 25-01-2010, 22:55
Thanks Madison. That will work for some of the parts, but not all of them, since sometimes we also want to add a change to the other side once it's been "mirrored"
Unread 26-01-2010, 01:04
President, VEX Robotics, Inc.
Austin,
While in the part you want to make a bend opposite version of, do the following:
1. Select the face or plane to mirror about.
2. Go to "insert --> mirror part"
This will create a new part that you can save as a new name.
You can add features to this part, but any change you make to the original part will also be made in the new part. Of coarse, with any linked part or feature in SolidWorks, you can break the link at any time.
We do a ton of sheet metal parts and this is how we model our bend opposite parts.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 26-01-2010, 02:06
Thank you Paul!
That worked for the most part. The resulting part was just 1 body though, and wouldn't let me use any of the sheet metal tools to operate on it. I looked through the options that popped up while creating the mirrored part, and couldn't find any promising ones. Is that the correct behavior? If so, what's the best way to add, for example, a edge-flange to the resulting part? I can think of "hacks" to do it (draw the desired edge flange in a separate configuration in the original part, and mirror that part), but I'd rather not resort to that unless that's the best way to do it.
Austin Schuh
Unread 26-01-2010, 02:24
If you want to add more sheet metal stuff to the mirrored part, your best bet is to just copy the part and flip all of the bends. Mirrored parts on sheet metal work best when the part is a true "bend opposite" part.
pic: Cyber Blue Twins - R1 (right) and R2 (left) Chris Fultz Extra Discussion 6 19-02-2009 22:42
How to filter the points to get only the left most and right most? tommy_chai Programming 2 28-11-2007 11:39
New Sheet Metal Pattern Query easydub Inventor 4 13-07-2006 13:55
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
Turning Left and right reilly Motors 2 18-02-2005 11:35
