Thread Tools |
Rating:
Display Modes |
How do omni wheels work
We are planning on using omni wheels but we aren't sure how they work.
Re: How do omni wheels work
Omni wheels work like a powered caster. They rotate when powered like any other wheel and give you flexibility of side movement as well. The rollers are aligned perpendicular to the wheels axis, this allows the wheel to roll on the rollers when a side force is applied.
You can also use omnis to climb over objects like 6" stairs http://www.chiefdelphi.com/media/photos/18050. Last edited by Alex Cormier : 26-01-2010 at 15:08. |
What are you looking to do with them? Are you going to try to go in any direction, try to turn better, or some other aspect? Most of the omni wheels that I have seen have allowed the robot to go in any direction. But I have seen quite a few that were used to make the robot turn a lot easier by putting them on the four outside wheels on a 6 wheel drive system. It all depends on what you wish to do with them.
![]() I just posted the image for reference. Last edited by Cyberphil : 26-01-2010 at 15:06. Reason: Wayyyyy too big of a picture |
How do you get them to move sideways? We're just trying to move sideways.
If you want to use omnis to move sideways, you could mount them in a holonomic configuration like this: / \ \ / |
You need to put one (or one set) per side. You want the wheels to form a box around the robot, something like this: |=| To move forwards and backwards, drive the ones on the sides of the robot. To go sideways, run the ones on the front and back sides.
#7
More than you ever wanted to know about omni wheels.
robocup.mi.fu-berlin.de/buch/omnidrive.pdf |
#8
The "omni" wheels are indeed just like a castor, but they are more stable with side loads then the shopping cart variety. They allow you to turn about the center of your drive wheels. DO NOT try to power them, because they do not operate well in that manner.
If you are looking to go forward, back, sideways and round and round, look into Mechanum wheels. Here is an example of them in an industrial application: http://www.youtube.com/watch?v=CjcyHicm3NA AndyMark sells a 6" and an 8" version as well. There are some issues with them, such as a certain level of finesse needed in the coding of the robot and each wheel needs individual power in order for them to operate properly. They also do not do well when one of the wheels is lifted off the ground. You may also want to look into using a gyro to maintain a certain orientation of the robot as well. Hope this all helps and good luck with the rest of build season. |
#9
You won't get as much traction out of them as you will out of a traction tread like a roughtop or wedgetop rubber and you may be easier for other robots to push from the side, but you will still have more pushing force with them powered than you would with them unpowered. |
#10
I can find you 100 teams that would say otherwise. Powered omni wheels are omnipresent in drivetrains that aren't 6 wheel drop.
#11
And they aren't exactly unknown in 6WD drop applications, either.
#12
You need them in this configuration for holonomic use of omni wheels:
http://andymark.biz/am-0478.html ![]() |
| How do you wire the inputs for holonomic drive (omni wheels) | star_lancer | NI LabVIEW | 8 | 22-01-2010 22:29 |
| caster wheels vs. omni wheels | gondorf | Kit & Additional Hardware | 4 | 23-01-2008 22:45 |
| How Do Mecanum Wheels Work? | SPARKY1688 | Kit & Additional Hardware | 9 | 08-01-2007 23:39 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| Omni Wheels | edomus | General Forum | 6 | 06-02-2004 13:35 |
