Go to Post and if you don't know what i'm doing, that makes two of us. - RogerR [more]
Unread 27-01-2010, 14:07
CVassos's Avatar
CVassos CVassos is offline
A man of many subgroups
AKA: Chris Vassos
FRC #2016 (MightyMonkeyWrenches)
CVassos is an unknown quantity at this point
Getting started with CAN/Jaguar
Are there any good explanations of the use of CAN/Jaguar and how to implement it out there?
Thank you, Johnson & Johnson, we are very grateful for your sponsorship
Unread 27-01-2010, 23:43
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
Re: Getting started with CAN/Jaguar
There are many sources I can think of that you should examine. A few I can think of off the top of my head are:
1. The Black Jaguar (MDL-BDC24) data sheet available from Luminary Micro. This contains information as to how to wire the CAN bus and tells a little about what is available. Other documents on their site might also help you.
2. To actually implement it take a look at the sample code (for Java, C++ and Labview) on FirstForge (firstforge.wpi.edu). Just examining the sample code should be able to allow you to gain enough knowledge to experiment with it and figure more out.
Hope that helps,
-Ian
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
Help Getting Started with VEX programming. Joe Johnson VEX 5 16-04-2007 09:01
Problem getting started with USB 6009 JimGRobot LabView and Data Acquisition 1 18-12-2006 09:15
Getting Started with Scripting LBK Rules Programming 2 15-01-2005 01:28
