windriver help
sorry bout the post below accidentally deleted it
Ok..now I load the program to my kit bot and the autonomous works get but the teleop wont run at all In the diagnostics section on the driver station i get an error Fatal error "Attempting to rescue an allocated resource" in Allocate() in C:/Windriver/workspace/WPIlib/Resource.cpp at line 79 if i go to line 79 it says 77-if (m_isAllocated[index] ) 78-{ 79-wpi_fatal(ResourceAlreadyAllocated); 80-return 0; and i dont know what this means could this be why it is not working and if so can anyone help Last edited by Rikard023 : 28-01-2010 at 10:32. |
Re: windriver help
PLease help im getting desperate
Re: windriver help
We had this problem too. Make sure you updates are all applied.
Did you have aprevious version of Windriver loaded on your computer? What platform is running Windriver. |
Re: windriver help
I didn't have a pervious version running i put windriver on the netbook FIRST gave then teams. I fixed my problem now though, I just re-wrote my program over one of the example programs FIRST gave us
Re: windriver help
We're having the same problem, but we have updated. Could you please explain how you fixed the error?
Re: windriver help
To explain exactly what i did i took my program i was already writing and just copied it to a different example template and it worked that and We wired the robot right this time post some of your code i could help
#7
Re: windriver help
We got this error when the code was looking for a sensor in the wrong (slot, port) combinations(s). Make sure that you're initializing your sensor objects to the correct slot and port(s), reboot the robot, and the problem should disappear.
| Dashboard Help C++ Windriver | ranc | Programming | 0 | 15-01-2010 15:26 |
| Please help Program Relays in WindRiver.... | programmr | Programming | 6 | 28-01-2009 11:42 |
| Need help in c++ and windriver | jkjohnson | C/C++ | 3 | 13-01-2009 18:50 |
| help:Downloading the project in windriver | mahmosh | C/C++ | 5 | 10-01-2009 10:08 |
